Serpent 720
#4531
Way to go DJ and Paolo!!!
Congratulations guys!!
#4533
rear exhaust means the exhaust port exits on the reverse side of the carb, which is the intake side. So the header would be on the side of the car. If it were a side exhaust engine, the the exhaust port would exit to the rear of the car.
#4536
5x10 is the larger inner bearing, and the 2 smaller ones are 5x8mm
#4538
http://www.abc-rc-shop.nl/
On the right you see the exploded views, and you can find every information you want there...
But probably you won't find this specific infomation there off course (Murphy's law)
#4539
The two small one's i already have.
Always go to the site from a well known racer on our MACH track.
Probably because it's the optional clutch.
#4540
braking system on the 09 edition
Hey guys I'm putting my kit together and I have a question regarding the braking system on the assembly book on page 13 on the top is says pad, metal, metal, pad is this the way it goes or does it go pad, metal, pad, metal?
thanks 4 d help....
thanks 4 d help....
#4541
