Serpent 720
#4441
Tire wear options
Can someone advise me on a tire wear issue when the left side tire wears 2mm faster then the right side. Should I use higher shore front and rear or true the tires bigger on the left side.
#4442
2009 will be good year
It is going to be a good year like I said before, because Ryan my 6 yr old son won his first club race at Homestead RC Raceway, 15 min A main with his Serpent 720 what a great day.
Also DJ you missed Ryan's spin out, he did it just like you.
#4445
Congrats to Ryan !...........
#4446
Good to here, Ryan will be killing us all very soon. Startign at such a young age is awesome. Good news on the spin out.
As for the tire wear. You must mean at the Homestead track. That tire gets like that with the high speed sweeper at the end of the track. You can do a couple of things. Harder tire on that axle, calculate how much larger to start that tire out at or depending on how long the race you can change that tire during the main.
Congrats again,
DJ Apolaro
#4447
I believe that this is due to the amount of speed and pressure that is applied to the left side when entering the sweeper at the end of the straight. I dont know what you can do to reduce the inequality of wear. Because if you true the tires larger on that side it may effect the way the car handles ih other portions of the track. I have the same issue with my son's carpet sedan, just on a smaller scale. Hopefully someone on this thread with more experience than myself can shed some light on the issue.
#4449
#4450
I have a LCG chassis but dont have the LCG monoblock mount.I have the standard height monoblock mount.Is there a regular two piece mount,can I use the regular height monoblock on the LCG.What flywheel would I use with that combo????There are two different flywheels ,right??
#4451
#4452
So in conclusion, if your going to run the LCG chassis AND the monoblock THEN you need the 31mm flywheel, otherwise you can use the stock flywheel, 33mm.
Hope this helps.
#4453
I have the same issue at the track i race, but then for the right side, to cure this problem i use the following tyre setup, this will have a better wear side to side after 30 min of racing i end up with .5 mm smaller on the right.
The setup:
LF GRP 37 shore 60.5mm RF GRP 40 shore 61mm
LR GRP 40 shore 63.5mm RR GRP 42 Shore 64mm
For your situation just change the sides (and tyre starting size) and you will be ok.
#4454
I believe it does. The 720 '08 comes with the Black Chassis (Non-LCG) and the LCG engine mount (Monoblock). As you know this an ok setup, but when I changed to the LCG chassis, I had to reduce my flywheel's diameter (change to the 31mm flywheel of course) otherwise it would be like sticking out under the chassis.
Hope this helps.
Hope this helps.
#4455
Thanks for the help with the flywheels,now I am wondering about the side pulleys.I bought a used car and dont know what pulleys are stock for the side?Can someone please tell me what pulleys go where everywhere in the car???Whats 24t 2sp mean??
