Serpent 720
#4276
#4277
looks sweeeeeeeeeeeeeeeet...nice driving............
#4281
Charge at 1.1
About the traction roll. does the track have high grip and at what part of the turn are you rolling. Also what is your set-up.
DJ Apolaro
DJ Apolaro
#4284
Hey guys... Im having trouble having a constant car throughout the whole main. The car starts with some trouble understeering, through the 10-15 minute mark, it has perfect steering, but at about the 35-40 minute mark, I find myself with a very nervous car that I cant control... Any suggestions?
#4285
Try starting with bigger tires with a little bigger tire split than normal to compensate on rear tire wear. It sounds like you are running out of rear tires.
#4286
There's some green for you Petey!
Some orange too!
#4287
clean paint job........................but i'm not a green kinda guy....
#4288
the track is a medium size with 2 hair pins at that time the track has a very high grip. Here is my set-up sir.
DROOP - Front 0
Rear 6
TOE - Front 1 out
Rear 2 in
CHAMBER - Front Left 2.0
Front Right 2.5
Rear Left 5.0
Rear Right 4.5
RIDE HEIGHT - Front 4.5
Rear 5.0
TIRES - Front 40 Shore/ 58mm cut
Rear 40 Shore/ 59mm cut
#4289
Sir,
DROOP - Front 0
Rear 6
TOE - Front 1 out
Rear 2 in
Front Right 2.5
Rear Left 5.0
Rear Right 4.5
Rear 5.0
DROOP - Front 0
Rear 6
TOE - Front 1 out
Rear 2 in
Front Right 2.5
Rear Left 5.0
Rear Right 4.5
Rear 5.0
I need more info. I need the entire setup. oneway, diff, lock, oils shocks, springs caster, all the setup info.
DJ
