Serpent 720
#2491
Not that I know of.
DJ
DJ
#2492
Use 803166 bumper. If you run TC you might have to shape it a little, but it is much stronger.
Use 808346 ball in the rear position on rear arm. It is steel, the threads are longer, and larger in dia. so they won't push in.
Dave
Dave
#2493
i broke 2 of the lower plastic bumper support already. i ended with NOT installing the 2 inner/center screws that holds the top and bottom plastics of the bumper. only the outer screws and clips holds the foam and top/bottom plastic bumper support in place. without the 2 screws, it now relieves the stress on the lower plastics at each bumps (especially head on) as the top plastic can freely bend inwards.
don't know yet the side effects of this approach
#2494
Originally Posted by GHETTOTEACHER
I have a question...
I have been running my 720 and absolutely love the thing. There is a weakness. The damn front bumper support. That thing broke when I was in a race this weekend. The body was misaligned and made a mess of the front end of the car. This is the third one that has snapped since I have own the car. The funny thing is that my car was not harmed or damaged anywhere else. Besides the 710 bumper conversion, does Serpent or any other manufacturer make a more sturdy front bumper??
Hi there
Use the Le Mans front bumper... once you put it on, you won't have to change the front bumper again... plus you get better steering
Acid
#2495
Originally Posted by Acid
Hi there
Acid
Acid
#2496
Originally Posted by redsand
I dont understand why the steering would be effected when running a lola style front bumper ? I see no correlation there.
I am not 100% sure but I believe that the Lola bumper protrudes more than the std bumper. So, by default if you mount your body with the Lola bumper, you will have to mount it further front to cover the all of the Lola bumper. Hence, you end up with more steering...
This is what I meant
Acid
#2497
Hi there
Acid
Acid
#2498
Ah I see So, it is not directly related to the lola bumper.
Acid
#2499
Hi Guys
Has anyone got more info on the adjustable ackerman for the 720 (803192)?
How do you know which inserts gives you more ackerman and which one gives you less?
Acid
Acid
You basicly have four positions. In order of ackerman the order is as follows:
short and wide
short narrow
long wide
long narrow
Going from most ackerman (biggest difference betweein inner and outer wheel angle) to smallest ackerman.
Especially going from the short to the long settings you need to adjust dual rate settings to make sure the steering lock is the same.
#2500
short and wide
short narrow
long wide
long narrow
short and wide
short narrow
long wide
long narrow
Thanks Julius, appreciate the info.
Acid
#2501
Originally Posted by dj apolaro
I do not use the 720 front bumper that comes in the kit. I use the optional one that is like the the one for the 710. Never had any problems!!
http://www.serpent.com/product/803197
#2502
Yes!!!!!!!!!!!!
#2503
Thanks for the ackerman info Julius, which settings do what , in terms of overall steering, etc... which setting gives most steering, which gives least... Thanks!
#2504
Originally Posted by RoyU
Got the 3rd one way today. As I was assembling it I could not get the e clip that holds the 1st gear/one way bearing on. I pulled the shaft out and layed it side by side next to the stock shaft and found that the pin hole for the 2 speed adapter is closer to the end by about 1 mm, the shaft itself is shorter by about 2 mm.
Anybody has this problem also??
#2505
As all parts have a tolerance sometimes the combination of both will create this problem. However in this case sometimes installing the outdrive 180degrees opposite will solve the problem. Then both tolerances cancel out.
Originally Posted by Dan_E_RCTEC
BTW, one of the front one-way locking pin holes would not line up with the out drive hole by a tiny amount requiring a drill through with a slightly larger drill bit. Not a big deal, but you would think that this would be CNC controlled and should be caught by QC. It seems that their quality control may be slipping a bit in a rush to get the new kits out the door.
