Serpent 720
#2071
Originally Posted by kyoshosan
Hi All,
Anyone running an O.S engine on a Serpent 720 ? I own a OS .12 TR-T R Spec and i tried to fit the Centax III on it, but the flywheel does not fit on the engine collet, it stays far way from the front bearing. Anyone had this problem before ? Should i change the collet ? is there a special centax for OS Engines from Serpent ? Thanks in advance.
Alex Kyoshosan
www.copainferno.com.br
Alex Kyoshosan
I suggest building the entire clutch first and check if you can setup the gap correctly. If all parts fit as intended, the "large" gap might be just optical.
Some engines require you to use the collet that comes with it as the diameter of the crankshaft is different. An example is the Mega ZX.
#2072
to all tunners
To ALL
I have a tuning question. I've noticed with full scale cars they tend to run alot of front camber and little rear camber F1 super V8, touring etc.. If the laws of physics that govern racing remain the same why is it opposite in rc racing.
My second
Tire and dampening selection
How do you choose a tires for an event considering there's so much you can do to gain grip.
Why do you choose the dampening you do, again considering that there are piston options and oil packages to choose from.
My second
#2073
Originally Posted by trickd122
To ALL
My second
My second
Well there is a host of reasons for the differences in the two things you said. One thing that is truely important to keep in mind is that RC cars have more grip that would a real car, more power in comparison to its weight. These cars are all tires and engines..
With the way roll centers are placed in rc cars to optimize their handling; tire wear and tire contact patch is maximized to make them handle as they do. Real cars always have an understeer problem. They try to make them steer more but it becomes a problem finding a good balance. It really is a different world these toy cars and wrightly so. If you were to compare the size of real shocks to RC car shocks they are a bit out of preportion. Our shocks are way to big; you might think by looking at them, comparing them to real cars..
We also use more caster and distribute our weight differently!!!
Hope that helps!!
#2074
Originally Posted by asil
hi, in my 710, it says to use collet that comes with the kit. but can not remember the case for 720??
Asil
Asil
i ran an os12tz-p-t5 on my 720. the engine did not come with any collet, i used a kyosho collet part which my lhs suggested. i did notice it has a bit wider gap between the crankcase and flywheel but i was able to trim out the gap. i think my engine's running fine...
#2075
Weight distribution is totally different from a V8 touring car, compared to a 1/10th touring car. I also noted a lot of caster in the v8 supercars, but then again, i also saw a lot of camber, which seems it has become less this year around... The cars are just different, although the same calculations apply, the variables are different because they're just different cars...
And well, formula one, have you ever run a Lola body on the 720? guess where those grip levels on a formula one come from
#2076
guys, when the word comes to F1, when we can decrease the amount of air enters under the chassis then downforce will be higher.. because air passing over the body slows down but under the chassis it just passes and because of velocity difference there appears pressure difference and air tends to lift the car.. I think they use diffusers on F1 cars to direct air flow to sides.. if we discuss about this we can make good projects on our rc cars
later
Asil
later
Asil
#2077
later
Asil
later
Asil
#2078
Hope that helps!!
Hope that helps!!
Thanks Angulo,
That answered the 1st part ....Now the second part.
#2080
#2081
Originally Posted by B4
Thanks nigelnuggets,
That looks like it to me. It would be good if Serpent put this part number with the set.
The one in Eben's post is the normal one.
#2084
Does anyone run the Orion .12 CRF in their 720? How do you like it and did you have to change the gear ratios like most have with other cars?
