Serpent 720
#1531
Originally Posted by rccobra705
Check out Serpent Austria in Wienna, which also is a walk in hobbyshop
Address:
SCHÖNBRUNNER STR. 159..
A- 1120 Wien..
tel. ++ 43- 1- 812 13 96..
fax: ++ 43- 1- 817 72 87.
www.serpent.at
Remenber that the euro is high vs the $ and Europe is very expensive. I really think it is cheaper to get on in the US.
Address:
A- 1120 Wien..
www.serpent.at
#1532
Rear lower A-arm problems
I was curious if anyone has run into the same problem I am having with the rear lower A-arms and pillow balls? It seems as though if I just brush up against a board (not smack hard) it pushes the rear pillow ball into the A-arm causing a toe-out effect. I even super glued it and that didn't work. I am thinking about threading in a set screw in before I screw in the pillow ball to act sort of like a stopper. But out of all the vehicles I have owned and raced, I have never ran into this problem. Any suggestions would be very appreciated. Thanks
#1534
#1535
Thanks Guys!!!!!!!! I will get ahold of Serpent USA tomorrow.
#1536
Congratulation to Walter Diaz for Making the Main at the Vegas Race. Good job Walter.
Leo, Nigel, Michael, And Randy: better luck next time
#1537
Hey
Yeah, I had the same problem and I believe that the problem was with the rear lower arms... manufacturing problem.... anyway, I changed the arms and have no problem... to be safe.. I also used the Mugen upgrade pivot balls...
Acid
#1539
thank you so much mr. morganti! car was dialed, brain fart caused me to tag a barrier and break the axle. 3 wheel drive for 30 minutes!
theres always next year.
Good luck in Kissimee, say hi to Raf and everyone for me!
#1540
gear diff
Hi, i on my way to change my 710 to a new 720 soon and the most of the new car i sure about but what i need some help with are the front and rear gear diff, if i get three of each front and rear to change wich silicon oil should i use in them?
Serpent get 10-11 types of oil and i canīt have a gear diff for them all, or should i?
Gidde
Gidde
#1541
Gidde
Gidde
#1542
Gidde
Gidde
don't worry too much on getting all the oils from the get go....
the kit comes with all the fluids that you need to bulid the car. Start with the baseline set-up that the kit provides and test THIS on your track to get a feel (rear diff @ 30K), I feel your changes should not veer off too far from the stock set-up...
you'll love the car! Drive Hard....
#1544
gear ratio
Someone know itīs some gear ratio table even of the 720, looked at myTSN but canīt find any there, there was a good one to download there for the 710 but itīs not for 720
