Diggity Designs Custom R/C Components
#856
Tech Legend
Trader Rating: 51 (100%+)
No problem as I love the graphite towers. Work great and look killer. I would be interested in the taller tower when available. Most tracks I run on are relatively rough most of the time.
Yeah I was having problems with Tech and being slow so I guess when I tried to post and refresh it put in my post twice.
#857
TC5 LIPO Battery Mounting Brace
Here is the latest product for all of us who are going LIPO. This is the Diggity Designs Associated TC5 LIPO Battery Mounting Brace. No modifications are needed. Direct fit for ORION 3200 and 4800 packs, PEAK RACING 3200 and 4800 packs, and the CHECKPOINT 5400 pack... With this brace your pack will NOT come out!! Check it out at our website www.diggitydesigns.com. We also offer some aluminum caster blocks for the TC5!
Damon
Damon
#858
You might have to build one of those for the SBV2 real quick...... Most of us on the other coast will be switching to LiPo here very shortly.......
But I can already see that if you do build one, the chassis brace will have to go.... However, you can just incorporate one in the LiPo pod...... Or whatever you want to call it......
I guess I need to thank you in a indirect way, my daughter grew up on your "family's" product......... Guess that's why she is so smart....
#859
Awesome idea Damon. also check your email please.
#861
Well, Im working on it... Have to talk with my homie that wanted to go with me and make sure he wants to go, if not then I have to run it by the wifey! I should know soon...
BTW, Dave Graboski is a Pimp!!
Damon
#862
I will be working on a LIPO brace for the SBV2 today or tomorrow and will be posting them soon, I will let you know when they are done!
later, Damon
#863
RedRocket
#865
Did you know that it is necassary to modify the arm to run these? I am running rubber tires on carpet and maybe it is because I am running high roll center on my front arms, but, when I installed the caster blocks I lost all down travel of my arms. I had to file out the inside of the arm where the back of the caster block was hitting. This was dissapointing to have to do this. The last thing I like to do is to have to make modifications with what I would expect to be a direct replacement part. Now if I break aan arm, I have to be sure to modify the new one. Just some thoughts. Or constructive critisizm. They do look good and seem to be stout.
RedRocket
RedRocket
Damon
#867
Yes - you do have to file a little bit from the inside of the arm to get droop. The extra material that we have added to the caster blocks make it so they are slightly beefier than the stock plastic ones. Some of the Team Associated guys who tested them for us said they had to file the inside, but they never broke an arm!.. You should be golden! Thanks for pointing this out for others...
Damon
Thanks for the info on your testing Damon. And for anybody who still has to do this, I actually used my Soldering Iron and a my knife to do this quickly. Smells a little but made it easy to do and quick.
RedRocket
#868
Hey Damon, yea he can be pretty bad at replying back on emails.... He is busier then hell these days. You can try him at (661)259-8772...... If you still can't get a hold of him, well his lost......
One other thing, would I be able to purchase a piece of Carbon Fiber from you, say about 3 inches wide by 10 inches long? Let me know.....
Thanks brotha........
#870
What do I need to do to get my 4300's to fit in my 3D08? They won't slide under the shock/battery holder.
