Team Associated TC5
ANYONE WHO WANTS ANY UPRATED INLINE BULKHEADS IV GOT AROUND 6 SETS LEFT IF ANYONES INTERESTED.
EMAIL: [email protected]
[email protected]
regards greig
[email protected]
regards greig
I just bought a used TC5R. It came with alot of extra parts, including several caster blocks. The blocks are all brand new , but are not marked. Is there anyway to identify them ( 2degree, 4degree,)? I can figure out if there left or right, but that dosen't help much.
Jim
Jim
Jim
Jim
SpongerX
Thanks I'll take alook when I get home. Not sure how I'll identify if there hard or soft, the blocks are all loose.
Jim
Jim
I don't have any 4 Degree caster blocks, can I run 2 degree and 2 degrees of kickup and have the same setup?
Jim
Jim
Yes and No
You'll have 4 degrees of caster going down the straight, but the kickup will encourage the front of the car to dive more under braking. The car may get a little tail-happy on corner entry. If you tend to push on corner entry, you might just gain some better balance.
In that case would I be better off using 6 degree blocks and no kickup.
Depends
If it were my car, I'd drive it the way it is to see how it handles and go from there. If it's twitchy in the rear under braking, try less kickup and see how that changes things. If it's stable under braking to the point of understeer, try more kickup. The kit setup -- 0 kickup 4° caster -- is pretty neutral.
Thanks jhberger
Sense I don't have the 4 degree blocks I'll try the 2 and 2 setup. What have I got to lose. I've been driving a FTTC4 and this week will be my 1st with the TC5.
Jim
Jim
Either way you should find the 5 nicer and better to drive then the 4, I went from a FTTC4 to a TC5 as well.
Hey guys I sold my TC5R and I still have the exotek conversion TC5X I will post pictures if anyone is interested I'll let it go for $55 shipped.
The Integy knuckles have less bearing play and more steering geometry, BUT the Integy C hubs are a waste, a ton of play and they bend when hit. With the factory plastic C hubs the plastic either breaks or they return to there original position. Go with the Integy knuckles and factory C hubs, you won't be sorry.
all are ready..........soon video-suicides-crashes ??? ???
what the hell did you do to that poor car??
