Team Associated TC5
Those bulkheads look the business , Are these being sold anywhere?
Hi Rick,
Does reducing the weight of the layshaft that goes through the pulleys and spur gear hub make that much difference?, i know it will be lighter, but will it be faster?. The reason i ask is, i posed a similar question a few months back about changing the steel cvd's to aluminum or titanium versions to reduce rotational mass, and many said it didnt make a difference, as the mass is close to the axis of rotation, nothing is swinging
Titanium Racing used to make a lightened layshaft. I bought one, but could not ever get it too work properly. It bound up when turning and made the drivetrain tight. I think the factory one is good, but an alloy one might be worth it especially if you tend to overtighten bolts and strip them.
TC5 with Exotek and Foam Chassis
my ride is up for sale... comes with exotek lower deck, upper deck and bearing holders to lower the center shaft. comes with new foam chassis also (top and lower decks)
you can view here.
http://www.rctech.net/forum/r-c-item...iced-move.html
you can view here.
@Tsquare , i noticed with the 6 degree blocks, that it is a little more stable on the straight, whilst giving slightly less corner entry steering, and more mid, exit corner over the 4 degrees.
The Shock tower mounts that Christer uses, has anyone else tried these, and what have you noticed?, i see he also uses the higher hole on the bulkhead i presume for less chassis roll, and the new shock tower mounts enables him to use similar camber height of that when he uses the lower bulkhead holes?
hey guys im hoping for some help, maybe just point me in the right direction. ive always been an offroad racer but just traded one of my SC trucks for a TC5 to give on road a try. im gonna put my RS Pro in it and have a redline 17.5, 13.5 and 8.5 as motor options. I have NO idea what gearing i should be shooting for, i know it has a 100t 64p spur gear. I would really appreciate any advice you guys would be willing to give me. If its not too much to ask, maybe suggestions as to what FDR with each of the 3 different motor options. Thanks in advance.
tc5 spinning out
i have set up my car and i have a problem..it wants to spin out turning right on a few corners...i turned the steering down on that side...i do have one more degree of toe in on that side would that make a difference...and how to you adjust toe in the rear...please help..i am new to the tc scene....3 degrees on left 4 degrees on right
Refer to the manual.
Front belt what size ?
