Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 03-14-2009, 10:08 PM
  #9046
Trader Rating: 11 (100%+)
Use this for the T-Nut replacement, much easier and works better.
http://www3.towerhobbies.com/cgi-bin...?&I=LX2869&P=7
Layin' Wood is offline
Old 03-14-2009, 10:16 PM
  #9047
Trader Rating: 49 (95%+)
Originally Posted by infamouse_1
ok i just got my tc5r and im planning on running a novak gtb 3.5r bl system.
what would be a good pinion gear for the 87t spur?
I run a 3.5 and use a FDR of 11-12 with good results, thats on nimh though, should be able to run down in the 9's with a lipo if the track will take that much
loopedout is offline
Old 03-14-2009, 11:06 PM
  #9048
Rommel's Avatar
Originally Posted by W.E.D.Jim
A Sedan body for you TC5 guys to check out!
...Jim
W.E.D.
Looks good
Rommel is offline
Old 03-15-2009, 11:02 AM
  #9049
Jsaves's Avatar
The old t-nut that some of you say to use. Are the ears as wide as the standard TC5 part? I had an old t-nut and the ears are not as wide so I thought it would create excess movement in the diff assembly.
Jsaves is offline
Old 03-15-2009, 12:23 PM
  #9050
trailranger's Avatar
Originally Posted by B-DAWG
Does anybody know if when you buy the alum outdrives for the diff. Does the thing (dog bone spring cup) that holds the nut come with it?
Why do you want aluminum? My experience with any metal outdrive is that they endup wearing faster than the $5 plastic sets.
recently a freind of mine ended up hitting a wall and broke the aluminum outdrive on the tc5. Under the same circumstances, I would rather break a $5 part than a $40 part.
trailranger is offline
Old 03-15-2009, 12:50 PM
  #9051
poochy's Avatar
hey guys,
Will this lipo sack http://www.smc-racing.com/lv_sum5028ld.htm fit into an Associated TC5 that has this http://www.ppdbillet.com/images/600_tc5_base.jpg as the weight plate under the lipo. Basically my concern is that the 5000 pack may sit too high and not fit under the upperdeck.
poochy is offline
Old 03-15-2009, 01:11 PM
  #9052
Hyde's Avatar
Originally Posted by lethallee69
any news on a new TC5 in the near future?
what do ya mean?
Hyde is offline
Old 03-15-2009, 01:17 PM
  #9053
Hide's Avatar
Originally Posted by poochy
hey guys,
I have both of them and have never had problems. I have 1mm under the rear bulkhead and roughly 4mm under the top deck, and I'm using foam tape to hold the weight to the lipo.
Hide is offline
Old 03-15-2009, 05:17 PM
  #9054
minittrackmann's Avatar
I no this is not the right thread but anyway. The alligator clips on the Muchmore CTX Cell master, can they be removed. I want to put bullets on instead so I can charge lipos. When I hooked the alligator up to a pigtail with bullets, it says check clips. So I dont no what the deal is....
Please help.
Cody
minittrackmann is offline
Old 03-15-2009, 05:35 PM
  #9055
2056dennis's Avatar
Trader Rating: 134 (100%+)
Default gearing for tc5r with tekin esc
guys im running rubber tire and have a tc5r with a tekin rs pro well i need to know some gearing for it im on a track that is 80/36 im also running lipo with a duo 13.5 and full boost on the esc with no timing on motor thanks for help
2056dennis is offline
Old 03-15-2009, 06:55 PM
  #9056
Im running almost the same as you, and im running 40/96 64 pitch. I havnt had any temps over 100 so far..
Old 03-15-2009, 07:19 PM
  #9057
2056dennis's Avatar
Default ok
what size track you running on and is your esc at 21* of boost or full boost
Old 03-15-2009, 09:09 PM
  #9058
STLNLST's Avatar
Trader Rating: 32 (100%+)
For those of you coming out to Speedworld for the Reedy race, Rick's set up from the world's looks killer on the track. The guy that ran it TQ'ed and won 13.5 this weekend. I guess I gotta step my game up
STLNLST is offline
Old 03-15-2009, 09:53 PM
  #9059
Team STPN's Avatar
Yes sir it was hooked
Make sure you do not use an Orion Speedo you will be left behind
Team STPN is offline
Old 03-15-2009, 09:56 PM
  #9060
STLNLST's Avatar
That's not a nice thing to say
STLNLST is offline
