Team Associated TC5
#8777
what's up guys, i know a longer wheelbase is better for a stable car at high speed long striaght away tracks, and a short wheelbase car is good for short technickle tracks(sorry for the poor spelling).
but i thought of this for better stearing in low traction tracks? i don't know if I'm the only one who thought of this. but it maybe has been done. or apart of someones tunning setting... not sure.
but if you put spacer on the front hing pins of the front a-arms and then, put spacers on the front of the hing pins in the rear a-arms. meaning... making the rear longer then making the front end shorter... putting more weight on the front wheels giving you better, quicker stearing... would that work?
EDIT: quicker steering on carpet and faster responce? it might throw something off though. not sure.....
I've raced on a very dusty track before couldn't hold my lines at all.... but i think with this adjustment i could've gotten better steering....
someone correct me if my theory is wronge
#8780
#8783
What is the difference between the Normal TC5 and the TC5R???
#8785
#8787
Steering probelms
I just built my 2nd tc5 kit. now i got the R version. I am using the futaba low profile servo s9951. I am using the inner holes on the steering blocks and using the 2nd set of holes on the servo saver.
I am hearing some binding from the servo when I turn the steering at 100%. I only have my EPA to 50%. I mad sure my servo horn is centered so I know that couldn't be the problem. I had to sutrn my dual rate down to 60% just to stop the servo from binding. I am using the 3pk.
Is there a step that I am missing or what should I change.
#8789
Super Moderator
Use your dual rate to adjust the size of the circle the car turns.
Nah, I am to lazy.
#8790
Can someone steer me in the right direction. im looking for a FDR for 17.5 and 13.5, big track with 115ft straight
