Team Associated TC5
#6736
mark i think you posted this same question on the ae forum .... if so go on there and read my post
#6737
well i think my problem is the screw lol also maybe the tires. i will be making those changing and try making things better. seems to be the second best car I've ever had. and i have alot of cars, so its always in my mind!
i bought the car second hand with this setup and a bunch of after market stuff also all stock parts. ken pepe's rubber tire setup
I would use this setup as a base and go from there. That is if your running rubber asphalt. which from the setup you posted seams like it.
#6741
Smaller spur will let me use the pinions I already have. I tried an 88 tooth spur and it wouldn't mesh with a 44 tooth pinion. So I'm using a 108 spur now, but need new pinions to get that low. I'll try the 100 tooth spur. Thanks!
#6742
Is anyone elses tc5r over weight with 5 cell ??? Im trying to balance left and right but its over weight already with no lead added !!
Electronics:
Lrp tc spec
07 orion 3.5
futaba bls 451 servo
airtronics spectrum reciever
13 gauge wire.... no excess
batteries 5x ep4600
amb pt
cheers
Electronics:
Lrp tc spec
07 orion 3.5
batteries 5x ep4600
amb pt
cheers
#6743
Electronics:
Lrp tc spec
07 orion 3.5
batteries 5x ep4600
amb pt
cheers
Electronics:
Lrp tc spec
07 orion 3.5
batteries 5x ep4600
amb pt
cheers
#6744
Electronics:
Lrp tc spec
07 orion 3.5
batteries 5x ep4600
amb pt
cheers
Electronics:
Lrp tc spec
07 orion 3.5
batteries 5x ep4600
amb pt
cheers
It comes in at 1420, balanced side to side I only had to add 45grams, and I didn't do anything to lighten it at all.
Futaba S9252
Novak GTB
LRP Vector
IB4200
#6745
wallstreet - I didn't post this on the ae forum, but I will go on there and look for your post. Thanks for the reference.
#6747
#6748
or8ital - if you mean the real TC5 spool, instead of the diff conversion, I ordered one Saturday night from amainhobbies dot com. THey had them in stock then.
wallstreet - Thanks for the reference to the ae forum. Checked it out and found a lot of good info there. Learned I wasn't the only one loosing a front wheel during a race. I thought I had failed to properly tighten a wheel nut, but found this happens a lot for some reason. In my first race with the TC5R Sat night, it would appear I experienced just about every problem discussed on that forum
#6750
I need recomendations of pinions gears and spur gears using a 4.5 BL LRP motor with a LRP sphere TC. I could use 64pitch spur on the tc5? I will apreciate all your ideas. Thank
