Team Associated TC5
#6091
Hi Rick
If its not too much trouble could you send me a copy of your setup sheet also, [email protected] Many thanks
Oli, UK
Oli, UK
#6092
Rick can you email me your setup from the reedy race.
Or if one of you guys who asked for the setup from rick and got it you can send it to me .
[email protected]
[email protected]
#6093
what is the JAAD spool where do i find one
i would also like reedy set up email is [email protected]
#6094
http://precisionrc.com/nv/car/produc...oduct_id=54280
#6095
Rear Shocks
Hey guys wondering if I can get more help, well just finished building my car but one of my rear shocks has a slow leak, I replaced the bladder and the bigger round foam but didn't change the small one that goes on the cap, anyway it's still leaking, any suggestions? Do you think I didn't build the shock correctly mabe the bladder is on crooked is their an easier way of building them?, or is it the cap itself? Thanks in advance!!
#6096
Hey Guys, I normally run the standard chassis and ITF top deck, but I wanted to go back and try the ITF lower. Problem is when I tighten the top deck I get front to back tweak. Like a teeter-totter when on a flat surface. I have narrowed it down to when I tighten the top deck. No matter how hard I push the shock towers down when tightening it still pulls everything in. I have tried 2 top decks and I keep getting the same results. Any one else having the same problem or have even noticed this? I checked all my bulk heads for tweak and went as far as breaking the whole thing down to just chassis, bulkheads and top deck to eliminate other components. I have another chassis coming, but there isnt a lot of wear in this one.
Any one want to check theres out and let me know what you find.
Thanks All!
Thanks All!
#6097
Are you using the o-rings for the top deck??? I noticed this when I got my lower chassis installed, it was very minimal and did not seem too have this when using the o-rings in the top deck.
Johnny55:
I would try going to the another manufacturer bladder it seems too help seal better. Just my $.02(not saying the factory ones are bad )
Johnny55:
#6098
Johnny55:
Johnny55:
#6099
Super Moderator
If you use the new washers that they are providing in the TC5R for the top deck you will elminate it on the car. Mine had the same problem and I still ran it. I have since switched my car to the washer setup like the 5R but haven't had a chance to run it yet but the problem went away.
#6100
Rick, or any other team drivers... Have you noticed this with your cars and do you just run with it?
#6102
The chassis tweak really depends on the chassis and top decks some are perfect and some require a little adjusting. Check to make sure when you put the top deck on the bulkheads that there is some clearance between the ends of the graphite and the aluminum. It might require you the dremel a little graphite off, I have seen this cause some tweaks. If you get everything bolted together and the chassis is still not flat you might have to manually twist the chassis to help get it flat.
#6103
