Team Associated TC5
#5266
Curious, are you recommending that because you've noticed that much of a difference? I'm considering going to the stiffer arms, but the stock ones have held out well as far as being reliable. Not sure I want to open Pandoras box on part breakage...for a small to negligible difference (if that's the case)
#5267
Has anyone had any trouble getting the shock shafts into the shock body. It seems the seal retainer is too big to go in.
#5269
Thanks Morris, finally got 1 in and you were right, they are a bitch!
#5270
T4mania, they are a tight fit...I used the flat back of a allen driver to help push them in. It has to be a small handle that fits into the shock body. Just be carefull to line the insert up strait and push it in till it stops...also, once you have inserted all 4, slide the shock shafts(with the pistons on) into the bodies and measure the length to make sure all 4 of them are the same. If they are not then the shorter ones are not inserted all the way...
#5271
The hard suspension parts definately help a TC5 that is setup for foam/carpet...I will be trying them on my rubber car also when the grip is high...the decrease in flex helps to free the car up when traction is high..
#5272
Im having a problem with my shocks too, i followed the directions, I put the o-ring spacer, o-ring and seal retainer, filled with oil, bled them and let them sit, when it came time to put the shocks on the car I checked the rebound again and found that the shocks were dead and oil was leaking from the top, i called AE and i was told to sand down the shock caps a little bit so i could tighten the caps more for a better seal. This did not work and all I did was damage the bladder, I built the shocks without the VCS foam like most people have suggested on here, I NEED HELP! anyone?
#5273
http://cefxraceway.net/?mainURL=%2Fs...tem_id%3D1zqn3
The car will definitely steer more. Steering = fast on foams
#5274
1. fill with oil as normal
2. place bladder on top of shock, making sure to let out any air trapped under the bladder.
3. Stack plastic shock end on bladder, then the aluminum blue cap over that.
4. Slowly start to screw on the cap, enough to get the threads started. Push the shaft in almost to the threaded portion. Oil/air may come out.
5. Screw on slightly more, making sure the shaft is not rebounding/sliding out. Everything should feel seated correctly. Continue holding the shaft in as you finish screwing on the cap.
6. Check rebound. You may need to partially loosen the cap if the rebound is too fast/too much, and let some oil out. You'll notice the cap gets to a point where you can feel it's not tight, then you can push in the shaft to get some oil out.
I had to play with the shocks a lot, and I also built a TON of shocks to be able to get a good feel for everything. Once you get the feel, it goes together pretty quick. It's not really hard, but if you just play around a bit, you'll get it.
#5275
Whats your preference on an outdoor asphalt medium sized track. Diff, Spool, or One Way.
#5276
Sometimes on a large sweeping track with medium grip, I will use a one-way.
I havent used a diff on asphalt in a long time.
#5277
While since we are finally talking shocks I will ask my question... again.
What packages are poeple running on their cars and how do they like them?
I am running 50wt all around wiht one rebound foam, and red losi pistons. with 50% rebound.
I like the car to have a slow weight transfer from side to side and I think it helps keep the car settled thru the chicanes. I also run loose so I need the suspension to work a little slower.
My shock problem. I keep having the bladders fall into the shock. Re-did my front shocks 3 times on friday night, Finally got pissed and went home. Was tired of dealing with them, If I had had them with me I would of tried to mount my tamiyas on the car.
RedRocket
RedRocket
#5279
You do not have to push the pin out. The blades are installed by stretching them on the pin with force. The blades are for the aluminum diff and aluminum spool...they are not for the oneway...
#5280
TC5 Aluminum 6 Degree Caster Block Sets
Associated TC5 Aluminum 6 degree caster block sets are now in stock at www.diggitydesigns.com!! Low pricing and they look sweet. No more breaking those plastic ones and they rid the block from flexing for better performance!
Damon
Damon
