Team Associated TC5
#4246
Not bitching
Just questioning the fact that everyone no matter what event there at is all running the same rubber tire setup..
#4247
Im sure their setups are not EXACTLY the same....for example...Im sure the geometry of the Juho/masters setup is sound for its application....but if you think that the grip level is higher than the Masters race, then maybe stiffen it a little....maybe stiffer shock springs or something....but major changes will probably just dial you out....
#4251
Hi guys!
Well. I also drove at the International Speed Weekend and used nearly the same setup as Juho's from the lrp race.
But we used Much More Sweep tires which were a little different than the V-tec or CS-tires! They had much more grip.
All Associated's had the problem of flipping.
What really helps was useing the thick upper plate, not the ITF.. It works good.
And you have to check you twaek after every run. This is very important....
#4252
PS- If anyone using Paragon and non Jaco's I can email set-up I used for that also.
#4254
Suspended
Some people have metnioned a set-up for rubber tire carpet in stock class, try this and tweak from there.
Front-
50wt oil, #2 piston
Gold spring
5.25 mm ride height
7mm droop (on gauge)
3rd hole out on tower, out on arm
6 deg caster
1mm of shim behind hinge pin mounts F and R
2A postion for mounts
1A ackerman
2mm wheelbase shim in rear, 1mm in front of arm
#3 camber link position
-1.5 deg camber
one way
Rear-
40 wt, #2
blue spring
5.5 mm ride height
6mm droop using gauge
3rd hole out on tower, inside hole on arm
2mm toe @ bulkheat, .5 deg outboard toe
2A position for mounts
3A camber link with 1 mm shim underneath ball stud
2mm shim at rear of arm, 1mm in front of arm for wheelbase
-2 deg camber
If I left anything out just ask,
Front-
50wt oil, #2 piston
Gold spring
5.25 mm ride height
6 deg caster
1A ackerman
-1.5 deg camber
one way
Rear-
40 wt, #2
blue spring
5.5 mm ride height
-2 deg camber
#4255
Hey guys- I received quite a few PM's for set-up. Rather than typing it each time, I am going to scan a copy of the set-up sheet tonight and send one email including all addresses.
#4256
umm, can't remember off hand, it'll be on the sheet I send you. Belt was loosest setting F and R I know. Standard cams just dont remember if I was med high and med low, I changed that around few times, but the sheet has what I ended up with.
#4258
ITF top and bottom. Was using O rings at first on top deck but took them out as it had a hint of push. After removing the orings and getting the chassis to where it felt balanced to my liking, I controlled steering with amount of sauce, which was really noticable. If I sauced 3/4 it had little push, if I sauced whole Front tire it would tip and roll, so it was a fine line.
#4259
Am I missing something here? I couldn't fit a 36 tooth pinion in the car while running the stock 87 tooth spur gear. I had to go down to the 84 spur.
How are you fitting a 43 tooth pinion with a 100 tooth spur? Is that using 64 pitch?
I just got my TC5 2 weeks ago, getting back into the hobby. Of what I remember and of what all my old buds are doing is running 64 pitch. It is a pain in the ass to set up but it is much smoother. I haven't tried it yet myself but will be before the weekend. Of what I'm hearing is that you have to install the pinion gear after the motor is mounted. I've also heard that you have to put a small knotch in the top plate so your wrentch can tighten the pinion. Any of ya guys that have been running 64 pitch confirm this or is there a better way?
#4260
Suspended
