Team Associated TC5
#3436
Sean
#3437
for brushless users or even 19T that need a larger pinion, a 112 spur makes it easier to increase pinion size without the motor running into electronics. Haven't tried a 110 but it may work too. The RW spurs are direct fit and come in 2 teeth increments.
#3438
saw the spool imn Darrens car ( mr TiR himself ) and they are in production..
Look strong too.
Hes also made some MIP type drive shafts and axles.
http://www.titaniumracing.com/
#3442
try Titanium Racing in the UK ( think Schmacher do it in the US )
Look strong too.
Look strong too.
I hoped on the tir site and didnt see any info on a tc5 spool. If anyone has any more info on the associated spools and or other brands who are making spools for the tc5 any info would be great.
#3443
for give me for being blonde.....but Brent....when you told me to place on o-rings on the top deck how exactly should they go on? The screws on the top look to fit into the counter sunk holes so would I still place an o-ring and then the screw?
Next Saturday should be fun.
#3446
that's something about the yokomo BD that i never quite understood, the top deck wasn't even close to symmetrical.
#3448
I am going to be running lipo's in my TC5 and was wondering what you guy's recommend for holding the packs in the car?
Cheers
Aaron
Cheers
Aaron
#3449
pics of my TC5 with unusual Lola body....
http://immagini.p2pforum.it/out.php/...3_DSCF0001.JPG
http://immagini.p2pforum.it/out.php/...8_DSCF0004.JPG
http://immagini.p2pforum.it/out.php/...9_DSCF0005.JPG
I used this setup: http://www.rc10.com/racerhub/setup/r...yrace_2007.pdf
BUT with no spool (stock front diff) and NO sway-bars....
tires: foam grp 35 shore whole front and rear
spur: 87 pinion: 20
motor: nosram storm 4.5T
esc: nosram matrix evolution IS TC
Really good performing car, the only problem I got was a melted rear diff after 4th run........ although it was 1/8 turn tigthened
however I've fixed it, now by putting Schumacher Silicone grease..... crossing fingers....
spur: 87 pinion: 20
#3450
Brent
Since there seems to be an apparent problem with the diffs melting, is Associated working on a new improved diff for the TC5?
If they are, are people that own the TC5 going to get replacements?
Charlie
Charlie
