Team Associated TC5
#2476
Originally Posted by kdub
On adjusting belt tension..... adjusting the cams so that the tabs move outward toward the end of the car will loosen the belt, towards the center of the car will tighten the belt.
Mid-High #10
Corey
#2478
Originally Posted by robk
The spool is $7.99 at horizon. Can't beat that.
#2480
Team EAM
Originally Posted by RoachRacing
I am working on putting my diff's in right now and I gotta say I am confused by the instructions. When it says you oppositely match the right side of the cam holder to the left am I correct in how I have the diff set in the attached picture? With the right side in the second space back on the cam.
Mid-High #10
Corey
Mid-High #10
Corey
Yes you are correct in that pic. If you want the belt tighter rotate the notch toward the center of the car and if you want it looser rotate the notch toward the outside (Front for the front and rear for the rear) of the car. On the front belt you can start with it in the loosest position as the belts are pretty tight.
EA
#2481
NOO!!! lol I was just about to edit my post to that. I was looking on Stormer for various things and I noticed the spool was only 5.95 and quick came here to change it... Looks like I got beat by about 10 minutes. Oh well.
#2482
Team EAM
Originally Posted by i am cornholio
hey all reedy race was great car was great, wish i could say the same for my driving, thanks to brent for the help, also to eric anderson for some motor tuning help, congrats to pudge, skidmore, brent, and the others in open mod 5 out of top 10, great showing for new car..also juho, drescher, and rick in invite, cars looked great, cant wait for next race
Nice meeting you there. I hope the motor and setup help helped you out some. Let me know if you have any more questions.
EA
#2485
Im new on this thread, and was thinking about getting one of these. Could someone please tell me if it comes with 2 ball diffs and if the center is solid or does it come with a center oneway. I also will be running on asphalt and dont want to get a "carpet" car. I currently run a Fk05 but I have always been an associated guy. I know everyone has a model preference but could someone please tell me if its a good choice the way the kit is right now out of the box for asphalt. Thanks
#2487
Originally Posted by wyd
Kevin you are going to have your TC5 at the Express race?
Brian,
I have a Nitro regional the following weekend so I will not be able to make it this year. I also have the Gas Truck Nats in August and then the 1/8th scale Regional in Sept. (come on RC8)
I plan on working the car on carpet first so I will hit Horsham a couple of times before the fall. Then get to Mimis for the carpet regional.
I will be running the car with 5 cells and a BL system (LRP) . ROAR will be on board soon enough.
Juan,
See you on the carpet.
EA,
Nice run in your main
Later
Kevin
#2489
Team EAM
Originally Posted by RandyB
Eric, can you post your set up that you had for Reedy.
EA
#2490
Originally Posted by EAMotorsports
Corey,
EA
EA
So my real question now is now with my front belt set at Mid-High #10 notch. That is refering to the left side of the diff which puts the notch at the 2nd notch in from the front of the car on both the left and right of the car. That is the what confused me the most.
Also whats with the cam holder B with the holes in it? There is no mention of it anywhere in the manual.
Corey
