External source connection for BC112C-A >
Old 12-13-2002, 07:07 AM
Canuck's Avatar
Trader Rating: 25 (100%+)
Default External source connection for BC112C-A
I have a Tekin 112C and 112A and would like to kmow how do I connect these chargers to an external power source ?
I see both chargers have a pair of tamiya connectors on the back (one female and one male).
Also how do I connect the 112A to the 112C ?
Can I just use the 112A connected to a car battery and how do I connect it ?
I have the manual but it leaves out all this info !
Thank's
Canuck is offline
Old 12-13-2002, 01:00 PM
rod_b's Avatar
You should be able to plug one into the other either way. However, the one with the available female connector is the one that will be connected to a power supply. If you bought either of these new, you should have gotten a cable with alligator clips for connecting to a 12V power source. Your power souce should have more amperage output than the charge rate of the 2 chargers combined. For example, if you're charging at 5A on both chargers...you should use a power supply with at least a 10A output. I'd go more just to be safe. As for using a car battery, I've only tried charging with 2 chargers off a car battery once. I was charging at 5A per charger and always got an error on the second charger. Probably because there was not enough amperage to support both charger.
rod_b is offline
Old 12-13-2002, 01:02 PM
Use the plug that the BC122a does not plug into to connect to a 12v power source. ?????The BC112C has an internal power source that works very well. Why do you want to connect to 12v???
Pit Crew is offline
Old 12-13-2002, 01:12 PM
Canuck's Avatar
Thank's for the info.
I just wanted to know this in case I decide to use either in a parking lot and of my car's battery.
Canuck is offline
