DARKSIDE MOTORSPORTS - "We Are What's Next"
#482
Glad to hear everyone is having good luck with the car.
How about we get some setup sharing going on?
#483
mike ERIC told me my car is on its way to you put the set you had on it
it was fast
#484
I'd be glad to share what I have learned. I have two cars - one silver - one black. So I can post them later this week after I re-measure the car and go through my notes.
I need an idea on how to do a brushless in 1/12 stock as they allowed the 13.5 in stock. I beleive over half the A-main in Omaha was brushless. I also heard that the roll out was 2.50. How do we get that gearing into the car??
Lastly I got an e-mail with set up info on the Gen-x car from CRC that talked about using 30000 or 50000 diff lube on the side tubes when the traction came up. This might have solved my issue on the 19 turn car that I have the Gen-X tubes on. Thought the fit was a little loose.
Grenade
Grenade
#485
Run an 88 spur, you can fit really big pinions then.
#486
All that said, the "kit" tube lube for the Gen-X is the blue-capped "extra-heavy" lube where for the CK 3.2R's it was the red-cap "light" lube (two step difference). Maybe you're on to something...
Scottrik
#487
The 3.2R I bought last July came with the white cap lube for the damper tubes. I bought some blue cap later seperately because the car had too much roll which I used on my Mx2. But it seems too thick so I need to look for something lighter. My white cap lube spilled out in the box all over the parts...was a mess when I first opened the box...so I don't have enough left over to try on my Mx2.
#488
#491
Originally Posted by Scottrik
WHOA...PLEASE tell me the HobbyTown 2-day isn't allowing brushless in Stock. As everyone is finding, this supposed "equivalency" is nothing of the sort now that people are finding they can gear the bl to the moon with no apparent penalty.
Are you using the Gen-X (Torpedo) tubes in the standard mount location on the MX2 and using the standard hardware for the tubes? if so, I think the "looseness" you describe is caused by the piston not being in as deeply as it is intended (causes a "wobble" at the end). The Torpedo tube assemblies are something like a quarter-inch shorter than the "standard" tubes. I am TRYING to finally get my torpedo tubes installed on my MX but I'm using longer hardware (the same DuBro 2-56 ball links for 4-40 rod I use for my tie rods) to get the pistons at the correct depth in the tubes.
Scottrik
Scottrik
#493
After a little more dremmell work - I'm able to use a 96 spure and a 38 tooth pinion with a normal motor. Brushless seems to hit more stuff so limited. I've also run the 88 spur, but dislike the loss of adjustment in gearing and I hate trueing tires to get the gearing correct with CRC High Rollers.
#494
I run a 96 spur as well, and have never needed to fit more then a 36 in my car.
If we were to put a 13.5bl in then the 88 would be needed to get the numbers right.
#495
I beleive that there is a separate class for the brushless motors. I'll confimr and post in the morning.
I used the longer pistons and the Gen-X tubes. With this set up all rings are in the tube and a little more movement in the rear pod.
Scottrik
