Marc's Winning car and setup!!
From http://www.kimihiko-yano.net/weblog/
CRC-Track-Magnet-Magenta front and rears front 41,5mm/rear 45mm-45,5mm
cells foreward (AP Chassis)
speed 12 Bodyshell
ride hight 3,5mm
0-5mm pod droop (strait when race ready)
70wd in center damper with red spring
white side springs med preload
CRC blue tube lube
low roll center kit
0.5mm front springs Hupo and 0.55mm in Marcs car both no preload
CRC tube lube white on king pins on Marcs car, non damping on Hupos car
1.5 camber
full castor with 10° block
CRC-Front brace
speed 12 Bodyshell
ride hight 3,5mm
CRC blue tube lube
low roll center kit
1.5 camber
CRC-Front brace
Did they redesign the V2 Endbell?
speed 12 Bodyshell
ride hight 3,5mm
CRC blue tube lube
low roll center kit
1.5 camber
CRC-Front brace
speed 12 Bodyshell
ride hight 3,5mm
CRC blue tube lube
low roll center kit
1.5 camber
CRC-Front brace
Actually...CRC-Track-Magnet = CRC Pro-Cuts
The team ran the new 38 mm Pro Cuts. Magenta front and rear.
Congrats to Marc, Hupo and CRC on a great race!
From Glyn Ward on RaceChat about the V2 endbell.
yes new one from orion has 8 holes round outside of bearing and has angle machined on location step for ventilation so locates on 4 steps 3mm wide
Originally Posted by James35
Marc's winning what event?
