Infield boarders
I got the 4" tape here:
http://www.identi-tape.com/stripes&checks.htm
When screwing the soft corners onto the main rails (which are filled with 2x2 and 1x2 wood), we were able to attach them in such a way that they skim right over the surface of the carpet, and yet always return to the same exact position after a car hits them! They work perfectly. The local racers at this track really enjoy this little track a friend and I made for them.
I believe the lane dividers are known as "Polymere" and are available from most any fence company that sells that that type of fencing.
Originally Posted by jbenthobbies
What did you use to make the soft corners?
A really good material for the soft corners is High Density Polyethylene (HDPE) also known as "Puckboard". A sheet of 3/8 or 1/4 inch thick is flexible enough to make a loop with, yet it is extremely tough. You can cut it with wood tools. Do a Google search for HDPE and you should be able to find a distributor not to far from you. A 4X8 sheet is not that expensive.
