Silver Can Motor Tips/Tricks
#573
Nope, that one has good torque...
#574
question: if i took an HPI saturn 20t/ansmann clash 21t silvercan and sandblasted it, would it pass for a stock silver can? or would someone spot something... because they seem to be OEM mabuchis or somethig similar.
#575
well, i dunno bout sandblasting but when i posted about modifying my sport tuned.....( i rebuilt it and modified it) i got my ass bitten off by the guys on this forum coz i was cheating....even though i had no intention of racing it....only to actually prove ppl wrong that once u pull a sport tuned apart it cant be put bak 2getha without it being obvious......mine looked factory....but yea
anyways i dont know anything about sandblastin or anything alike.....i just thought i would let u know that u are bout 2 get r@ped!!
#576
well, i don't race, i just want to know if it would pass as one. i doubt it would even need sandblasting, just the label peeled off.
#577
Nope. Too easy to spot. I don't understand the logic. Why go thru all that trouble unless you're racing or just trying to impress with your fast silvercan
#578
i guess not... oh well just curious.
#579
No thoughts on my?
Don’t think it's necessary to post on new thread.
Hey guys,
I am New to the forum, and greatly inexperienced in electric racing.
I just bought a Mini, I broke in the motor using the water method.
The thing is much faster in reverse then forward. Is there anything I can do to fix this? I assume this has been covered; a good link would be appreciated
#580
its timing is out. have you been tweaking the stack? if so turn it back the other way. or put your motor on the other side of the car so it spins the shaft/belt the same way but the motor is going round the wrong way...
#581
ok sounds like it came out of the factory faulty. are you running it in the car or on a battery pack/power supply? it could be your radio endpoints not set up properly.
#582
as for turning the motor it's on a mini and it would be sticking out of the car if i fliped it.
I guess I will pick up another motor
#583
mabuchi
Hi,
I believe mabuchi's are designed to be faster in reverse (clockwise) rotation. So maybe nothing wrong with your motor.
good luck.
good luck.
#584
i think they have 0deg timing so they are the same in forward and reverse. most electric drills run mabuchis. they run the same both ways.
#585
ChuckWick357 Hey guys,
I was just trying to build a motor to keep up with Doc
