Wind came loose... >
Wind came loose...
Wind came loose...
Old 03-01-2006, 08:01 AM
Default Wind came loose...
Hi i had a new blueprinted stock monstor.
i had once race meet on it, about 20minutes use. it was not as fast as the other stock motors i ran against.
i took it apart to inspect, the comm was still near new. no need for a cut.
i notice however that one of the wind was loose. (not broke but just loose) i ran rollout of 26mm and never temp over 45C. i have a fan on motor.
what cause this? faulty motor? will a loose wind effect performance much?
my friend sugested to superglue it back, but said that it will be unbalanced. what can be done?
cheers
noobie is offline
Old 03-01-2006, 02:44 PM
dontfeelcold's Avatar
Trader Rating: 22 (100%+)
it was a faulty one, it happens sometimes.
dontfeelcold is offline
Old 03-01-2006, 05:23 PM
Speedo's Avatar
I have a 19T motor like that. It just happens sometimes with machine wound stuff.
Speedo is offline
Old 03-01-2006, 10:58 PM
Go back to the store you bought it from they should exchange the arm for a good one.
If not you can always try mailing the tuner directly. Most (all?) tuners are very good in the customer service department
vassago is offline
Old 03-02-2006, 03:10 AM
VenomWorldOrder's Avatar
wind came loose?? well then, don't eat so many beans!!
VenomWorldOrder is offline
Old 03-02-2006, 04:09 AM
shouldn't you be out protesting somewhere?
noobie is offline
