New Corally SP12X
#286
Yeah you still have some greese on the o ring. Corally diffs are spot on, but you have to get that ring totally clean. It can help to rough the ring up a little.
#287
Originally Posted by Switch Blade
question: I just drilled the servo holes back far enough to use the associated front end and when getting everything all set I noticed that the spur would always slip until I had it locked down to the point where the spur would turn the armature. I backed it off since that is not right, but I can move the spur gear still. Is this just the way the corally diffs are and should I be able to slip the spur, or perhaps do you think I have some grease on the O-rings?
Otherwise, it is almost always a slippery O ring. As Matt says, rough up the washer on some 400 grit wet 'n dry, and do teh same to the O ring. Clean the O ring and the groove with motor spray, and wipe down with a clean paper towel. Drop the O ring into the groove, put the washer on, and keep all grease away! HTH
#288
Originally Posted by Bob-Stormer
Anybody aware of any solution to making rear 1/2mm ride height adjustments? 1/4mm adjustments would be nicer.
When the car wears in to 3mm of rear height, I'd like the option to go back to 3.5mm (or even 3.25mm), not 4mm or more. Can't do that with the stock adjusters.
I suppose it could be argued that a person could have an additional set of tires trued to say 41.5mm ready to put on when the ones your using hit 40.5mm (giving you back 1/2mm of ride height), but that's not a very good solution.
Ideas?
Ideas?
I just received my 12X the other day and Wed. ran it for the first time. I already need different adjusters than what comes in the kit. I am a CAD designer and work in a tool shop. I have already designed and manufactured custom parts for other cars. I am thinking about doing a set of adjusters that would fill the void from the kit pieces. They would be made from delrin and CNC machined. If there is interest in these pieces please let me know as it is almost as easy to make 5 set rather than one. Probably do the 1/2 mm steps too.
Pic of 2.5mm added.
Chris
#289
Pic of 2.5mm added.
Chris
Pic of 2.5mm added.
Chris
send me pm with the details!
Greetings Ollie
#290
If you can do those adjusters and ship to the UK i would take a few sets. I dont mind ordering sets for people over here either.
#291
I'd like sone too - PM sent.
#292
Chris
#294
One last thing. I never could figure out why I could never move the motor far enough to fit larger gears on it, until today when I saw that it is the graphite brace in the rear. Is this a high stress area, or could I dremmel off a 2 or so mm to move the motor farther forward? the only other way I can see using larger pinions is by using a 90 tooth spur, especially when gearing a C2 at 53mm. Brushless I dont see a problem since I often see them geared at 32mm.
#296
Will using a smaller spur/pinion aid in more rear grip since the motor is going to be farther back? Is it a negligable affect or greatly noticeable?
#298
perhaps Ill only spray the rear of my bodies with 1/2 a coat of paint and the front 3 or 4 coats to even it out a bit
#299
i havent noticed much change in rear traction.the cars have a ton of rear traction and it kinda gets to a point of being hard to see differences in rear traction.the biggest gain is the gearing you can run.it allows me to gear the piss out of my 19 turns.
