22SCT 3.0 rolling off power
Hi-
My 22SCT handles great and has good on power steering but it quickly rolls over if Im off throttle in a medium tight turn.
My setup is mostly the default setup in the manual.
I did change:
* orange springs in the rear
* medium swaybars f & r, minipin tires with 2 rows removed in the rear and
one in the front.
* I moved the front springs to the outer hole in the bottom.
I would like to enter a corner at higher speed and use the brakes to gain more steering without instantly rolling.
Ken
I did change:
one in the front.
Ken
What kind of track are you running on? That would help a lot to help give you advice. You might gett more help in the off-road section then the on road seaction of the forums. You might want to lower your ride height. You should also break before the corner not mid corner.
Thanks, I posted in the wrong forum, my bad
