8ight t 2.0 flaws and fixes
Here ya go. This should answer you plus much more.
http://www.rctech.net/forum/nitro-of...ght-2-0-a.html
What I have discovered so far.
1. Rear hubs bearings will wear out fast (outer). Problem they were to small. Fix kings head rear hubs (alum). They come with the larger diameter (outer) bearings. don't buy the losi alum hubs you will still experience the same problem.
2. Shock tower screws F/R. Problem they have a tendency to back out. Fix use longer screws with lock nuts.
3. Handling. Problem it turns on a dime. Fix hang on and enjoy.
4. Speed. Problem its fast and smooth. Fix hang on and enjoy.
Dont just check
REPLACE the outer wheel bearings
and REPLACE the shock ends
