big problem with glitchy servo
big problem with glitchy servo...UPDATED!!!
tonight i brought my buggy out to race and after a few mins i finally got it started and was warming it up and twice my throttle servo stuck wide open and i have no idea why. im not sure if the receiver got hot or if my servo is faulty if i got bad reception or what but it was still sitting on the starter box so i killed it but any help would be appreciated guys
my setup
os speed
spektrum DX3.0 w/ stock uncut antenna receiver
Protek LiPo
Protek Regulator
hitec 5965 throttle brake servo
my setup
os speed
Protek LiPo
Protek Regulator
i would start with the lipo and regulator.. .i have read that a lot of people have had similar issues..
well what should i do with them as they seem to be working fine
ya i could try that but wen the buggy is just sitting like when i got it home i couldnt get it to glitch or stick or anything but once the motor got to temp it started getting glitchy and sticking wide open which is making me belive the receiver is getting hot.
could that cause it??
you could just unhook the servo from the engine and just with the controller go back and forth untill maybe you get a glitch. its prolly not your engine heating its just the time it takes to heat up your engine your servo might start to bind, maybe just take it apart and look at it
well i bought this servo used and it had to be sent in for warranty repairs for a bad motor right before i bought it so maybe its acting up again.
i took it and just went back and forth for about 10 mins and it didnt do anything and that was with the engine not running
i think tomomrow im gonna try just sitting there moving it and seeing what it does if its smooth ima take a hair dryer and heat the receiver up a little bit like if the motor was running and see what happens and if it does it again ima try a different servo..i think this one is gonna take some time to figure out
Just a thought, but you could be getting some sort of interference from your engine. If the servo does not act up while the engine is off, That would suggest some engine interference. I wouldnt heat up the reciever until you've eliminated everything else. Hope this helps. Btw if you're the kid from crcrc I will be there this coming friday and can help ya out.
ya i am from crcrc and ive never heard of engine interfirence. so should i try like mounting my receiver somewhere else and seeing if it work
the motor heatingup and causing it is kinda weird I had a bad switch that was causing mine just a thought
I had a buddy that just went through a similar issue with his lipos and reg. It appeared like the reciever and servo was the problem but come to find out it was actually the regulator. As someone else stated try using a normal rec pack and see if the issue goes away with the engine running.
What we found with his was the reg would get hot when the motor was running. It wasnt getting enough air flow to keep it cool so it would shut down and with no mechanical failsafe his throttle would open up just like yours.
This little problem wound up costing him two regs. Although they work they dont handle the current near as well as the use to and heat up much quicker causing them to shutoff when they shouldnt.
man this sucks cuz there could be so many different thing. i dont run a switch so thats eliminated
i have my regulator mounted on the outside of my receiver box for that reason so it stays cooler but the buggy wasnt moving when i was warming the engine up. still doesnt seem like that should be the problem but i guess it could be.
maybe ill take the pack out of my revo and try it
ok guys after some testing it seems that its something to do with the regulator.
i went down and for the first 15mins just sat and throttle and turned the wheels and was fine then i kept feeling the regulator and i noticed the regulator started to get hot after about 20 mins and the throttle servo started acting up and it was sticking wide open for up to 10 second sometimes but the steering servo didnt act up at all. it seems as if the throttle servo doesnt like to be under load as when it sits neutral it makes a digital beeping noise and when i go wide open and let off it stops making the noise and sticks for a few secs then will go back to neutral.
so my question is do i need to try resetting my servo horn so there isnt as much load under neutral or should i get a new servo
