Reedy!
#226
Can anyone suggest a rollout for the Challenger 19T? We're getting these as handouts for the TCS Canada finals, just want to make sure I have the right pinion range..
It's on an MSX with 18/36T pulleys, outdoors, large but technical track, on Tamiya Rubber.
Would you suggest swapping out the stock springs with the other available type?
Thanks!
Thanks!
#227
I don't know the circuit in question at all, but would suggest following for an outdoor track. Start practice at FDR 5,0, and watch the brushes and the temperature. You can probably go to 4,5 or lower, pending on the outside temperature and track layout.
Go for a can temperatur of 70C, and watch for discoloration of the brushes. The motor handles the heat pretty well, so for the finals you can probably go up a tooth, and change brushes.
Best,
Peter
Best,
Peter
#229
#231
Best,
Peter
Best,
Peter
#233
#234
Rick,
Any news on the new hard cased lipo saddle packs? When will they be available or does AE have them in stock now?
#235
#237
35C 5000 LiPo
Good news! Keven Hebert just won the Super Stock 13.5 class at Cleveland using Reedy's 35C 5000mAh LiPo battery!
#239
Rob Lovely is going to the dirt with the B44
