Convert your starter box to LiPo
I suppose the foam would help protect the lipo if you were to drop your box.
I converted my Mugen Starter Box to LiPo as well, using two Hobby King Flightmax 4000mAh 2s 25c hard case packs. I have to admit, I should have done it earlier. It's truly amazing how much more power my box has. I no longer fear breaking in new engines (although I do pre-heat them of course).
Nice side-effect: these packs can be run in my Associated B4 buggy, too!
Yes the foam insert is to protect the battery if the box fall.
Iam just in the process of changing my starter box and i will be using a 4S 20C 2650mAh Lipo with deans plugs and also a low voltage buzzer/alarm just to make sure iam not killing the lipo.
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
here is my starter box that i use for both truggy and buggy.. wife made the little pouch for the needed tools if the normal ones go walking off by another racer... jeremy
You'll be amazed by the performance...
rather than convert the starter box to lipo, why not convert the car to lipo?
http://www.rctech.net/forum/electric...onversion.html
