Serpent Cobra GT
#796
when installing the set screws onto the 2 speed shoes, how far should the screws be in?
Thanks in advance
Thanks in advance
#798
Think the original poster may be referring to the M3 set screws that load the balance pucks - I'm so used to building 966/977 two speeds didn't even notice that there isn't even a reference to them in the Cobra instuctions , but typically the screws are tightened until you just start to lift the shoes off the hub.
#799
Thanks Vic
#800
LRP
Tony:
I bought the LRP arms and they are great. My car is very stable and the conering is tight. I went from B main to A main. I recomend the LRP arms to anyone who wants to drive smoother and tighter lines A,B,C, or D main drivers. These can help maintain your set up even after you bump the boards.
#801
Anybody running the king headz aluminum clutch shoes? The make 2. A 7075 material and a 6061. 7075s should last longer no?
#805
Lock tight the engine screws. The torque motors will vibrate them out...When in doubt lots o lock tight!!
#806
EVO 13, It depends on the size of the track. But in our track the stock 45/19 2nd gear is more than enough. Im using the short double bended manifold 41019 and the 2052 pipe. This setup paired with a Murnan Virtus is just crazy fast.
#808
Cobra TQ & Win @ Port Jarvis
Jose Almonte TQs and wins @ Hot Race Race in Port Jarvis, NY this weekend.
#809
#810
