Hpi Pro 4
#1426
Originally posted by rc-zombies
I had the Evo2...great car and craftsman ship... yea..on that car it's drilled for 4 and even the outdrives have mulitple slots...
can't wait for Xray to put out a shaft 10th sedan...
#1427
HB GRAPHITE BUMPER SUPPORT
For those looking to get the HB Graphite bumper support...
Stormer Hobbies has them in-stock... nothing at Tower yet.
https://www.ssl-stormerhobbies.com/c...pl?pn=HOT61131
#1428
gearbox...front so far
hi, building the car im up to the front gearbox assem. now.
the lower half is on the chassis already but when i tighten all four screws for the top half, the input shaft wont spin as free. no problems with the oneway though.
shimmings as per instructions.
anyone know why this is happening?
thanks
thanks
#1429
How about some more teaser pics for those of us still waiting on the car?
I'm assuming they left HPI on the 11'th? Any updates on that? If so, chances are I could see one by the weekend.
Steve - I know your reading this, Don't just lurk, say something! Who knows, I may be at trackside sunday if the bugger comes before the weekend.
#1430
#1431
Re: gearbox...front so far
thanks
thanks
#1432
zombies - evil... pure....evil. I meant of the car - not the HPI pics.
#1433
#1434
Re: Re: gearbox...front so far
Originally posted by Erik Shauver
Check this link Pro 4 Manual - #185 as it has the newest instructions.
Basically Check out pages 12, 14, and 15. There should be NO shims on the front input shaft. There should be 2 shims on the gear side of the one-way. The diff has one shim on each side (2 total). The rear input shaft has three 5x10x0.2mm shims and 3, 8x10x0.2mm shims, see the illustrations for exact location. Try this EXACT shim scheme and recheck the smoothness of your drivetrain. Note: the 8x10x0.2mm shims require a delicate touch when installing the gearbox top half... if they are bent/ bend at all, they need to be replaced as they will cause drag on the bearing.
#1435
Re: Re: Re: gearbox...front so far
#1436
just got back from racing my Pro 4 and must say it handles pretty well. a little fine tuning and this car is set. also, surprising how quiet the car runs.
i given our local shop owner a test run and he nailed some guy standing there on the track. the impact slightly bent my front CVD.
for any new racers out there, please do not stand in the middle of the track to pick up your car if you suspect anything is broken. and please for goodness sakes, do not drive in the reverse direction!
#1437
racer - Do you run on carpet? How's the stock setup with rubber carpet?
#1438
yes i run on carpet with rubber. the stock setup runs pretty well. but kinda lags abit while running through the chicanes (turns). overall, the setup is fine. just need to play with the springs.
#1439
Cool, I'll try and see if my losi springs fit the shocks or not.
I hope it comes this week.
#1440
front gear box
Thanks for all the replies.
the shimmings are done as told in manual.
both the oneway and the input shaft is fine spinnning before the top half of the box is screwed, but when it is theres drag.
ive checked that its not the oneway cuz i had the top on without the input shaft, its the shaft thats causing the drag.
the bearings seems to be a tad too tight. not sure
MORE HELP PLEEEEEASE!!!
