RC8 engine shimming
RC8 engine shimming
Hello. I need a quick run-through on how to shim a brand new B5 so that the pilot shaft isn't sticking about 2mm past the clutch bell... I have some small copper washers (losi shims) some medium silverish (losi) and some 7mm big ones... Please help, and any help is awesome!
-Erik
-Erik
I had to put 3 small shims on my go 3pt i put them on the front of the clutchbell unter the screw.
Every engine is different I have several speed engines all the same version all with the same clutch/ flywheel and they all shim out differently. Every engine is just a little bit different. Kyosho makes the beat shim kit I have seen they include shims in .1, .2, & .3mm this allows a perfectly shimmer clutch bell every time.
