EAMotorsports discussion thread
#2433
Funny Eric. I guess thats what happens when the "Sponsor" keeps the best batteries and motors for himself.
#2435
Originally Posted by jdwca
Bill, is that goodbye TC4?
#2436
Any word on the Carpet Chassis for the BD???
#2437
Hi Eric
monster stocks the com seems to be a bit on the small side now but boy dose she go why is this, and what diamiter could i go to without all the segments coming apart
#2439
Originally Posted by StephenSobottka
HAHA! TOASTIE! That guy is a riot man, lol
We sure would enjoy you guys coming down Stephen so give it a shot if you can, of and tell your Dad I said hi!!
Atlas Copco- the reason the motor feels better with a smaller comm is that you have reached that "sweet spot" on comm size. This is why tuners like EA will usually take handout motors at big races and cut them like 10 thou right off the bat- that way the comm will be approaching optimum size near the mains. AS far as minimum size EA can correct me but about .270 is where they start getting pretty thin. Also, even though the segments might not come apart, when the comm is too thin it starts to lose a little power. I believe it's because the thin segments can't dissipate the heat from arcing fast enough but I may be wrong. EA will know.
#2441
Originally Posted by ATLAS COPCO
Hi Eric
As the com gets smaller, the brushes develop more "wrap" around the com. This results in more RPM. At the same time, the motor becomes less efficient, and heats up more in a run.
Generally motors with a bigger comm can make the same amount of power, they just have a powerband that is more in the lower RPM ranges. You can still maintain the top end speed by gearing up a bit with a larger com. It will generally run a bit cooler and fade less with a larger com as well because there is mroe copper to disipate heat, and there is slightly less "wrap" around the com.
I won't run any standard size com any smaller than .270 inches. They start at .300 (I think) before they are cut for the first time. For the larger mid com motors like the Reedy quad mag 19T and the Reedy Kr, I wouldn't run them any lower than .310.
Some motors tend to have a sweet spot for the com dia, but it varies from motor to motor. It;s hard to tell just off hand what a specific motor will run good at. Hope this helps a bit.
-Korey
#2442
Thanks for that Sushi boy
#2444
Sushi boy what if i shaved of a sma ll pice of the brush on the leading edge with a small com?
#2445
Team EAM
Hi Eric
EA
