Mugen MBX5T?????? >
Mugen MBX5T??????
Mugen MBX5T??????
Old 12-29-2007, 10:38 PM
Questions?? Mugen MBX5T??????
i am going to buy a mugen and i want to know what parts are the most fragile on that car so i can buy better ones in advance
thanks peter
playboy is offline
Old 12-29-2007, 10:56 PM
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
thanks peter
i have been racing a 5T for awhile and only broken one front lower arm and one rear lower arm...the 5T really doesnt have a weak spot...
Jason Halvorson is offline
Old 12-29-2007, 11:00 PM
ok thanks
do they sell rpm arms for that truck?
how much are they?
playboy is offline
Old 12-29-2007, 11:05 PM
ok thanks
how much are they?
no rpm does not make arms for the 5T...the stock arms are strong, and the breaks were just from alot of hard racing...if you get the prospec there is no reason to upgrade anything...the only mod i would consider is the losi 8T wheel adapters, this mod gives the 5T more low speed turn...
Old 12-29-2007, 11:43 PM
Trader Rating: 132 (100%+)
What is the difference between the losi and mugen wheel hexes?
BTW, I agree about the mugen being super strong. I have taken some serious hits and it just takes it all in stride.
badaml is offline
Old 12-30-2007, 08:58 AM
the losi adapters make the truck narrower, making it have more low speed turn...
Old 12-30-2007, 09:05 AM
The mugen is pretty much indestructable. My dad races one and has only broken one front arm when he hit a wall. He also runs the buggy wheel hexes so that it is narrower, which is necessary since we run on an indoor, tight track.
whoajoe is offline
Old 12-30-2007, 09:31 AM
thanks guys
what kind of motor is the best suit for that car
i dont know if i am going to get a .21 or a .28
playboy is offline
Old 12-30-2007, 09:37 AM
thanks guys
i run both a .21 nad a .28 in mine...
Old 12-30-2007, 09:47 AM
TonysScrews's Avatar
Trader Rating: 13 (100%+)
Most guys lose the stock steel brake discs and rubber pads. Just use the metal calipers on one of the aftermarket brake discs (I personally use the TTR option discs part # PD1861). Cradock, Racer's Edge, Avid and a few other make discs as well. Also ditch the stock 1.4mm white shock pistons and use the 1.5mm black shock pistons.
The rest of the truck is bullet-proof. ProLine now makes 17mm LPR truggy wheels to run the newer LPR tires. If you want to reduce unsprung weight, get some lightweight pillow balls. There are several out there: Dace, Mugen, Innovative Design, etc).
As for a motor, on the track the .21 works great and gets better run time. For bashing the .28's are a lot of fun but suck more fuel.
Best of luck,
TonysScrews is offline
Old 12-30-2007, 10:05 AM
Best of luck,
well if you want to go into more detail...i also run after market brakes from AVID and run the 1.5 pistons, but i do not see this being needed, but yes it will help the truck preform better...i also run the dace lightened pillow balls and the proline LRP wheel and tire combo...infact if you really want to get in depth i do not run the Al chassis braces, but instead run the plastics cause i feel the Al ones make the chassis to stiff...oh i also have a tonyscrews kit...
Old 12-30-2007, 12:51 PM
stu541's Avatar
Trader Rating: 17 (100%+)
Default 5t parts
They are both right. the cradock brakes are nice and I would keep extra ring and pinion gears in your box just in case. spiral cut gears always make me nervous. other wise build it and run it you won't be dissapointed
stu541 is offline
