How you clean your rides? >
Old 02-11-2009, 12:03 PM
  #16
DRRC's Avatar
Trader Rating: 59 (98%+)
Originally Posted by yaright
Remove tray, motor and fuel tank. Stick in dish washer.LOL
Whaen the wife finds out... run for cover
does this work
if it does I will try it and the wife will never find out
If she does there will be a car more airborne than it has ever been
DRRC is offline
Old 02-11-2009, 12:27 PM
  #17
PTP Racing's Avatar
I googled it and found their homepage and ordered it direct. I think 2 cans shipped was just a little less than $24.
Maxima Racing Oils or SC1 ought to get you there.
PTP Racing is offline
Old 02-11-2009, 12:35 PM
  #18
slaytanic's Avatar
Trader Rating: 20 (95%+)
I'm surprised Porkchop hasn't come on and told you to put it in the dishwasher yet!
slaytanic is offline
Old 02-11-2009, 01:42 PM
  #19
Trader Rating: 70 (100%+)
Has anyone used PAM yet? We used in on our real racecar under the rear wheel tubs so the rubber from the burnout wouldnt stick. Cheap, easy, and heat resistant!
PROMODVETTE is offline
Old 02-11-2009, 01:59 PM
  #20
t0adman's Avatar
When it's extra dirty or muddy I like to soak it in a very salty brine for several days, then take it out and let it air dry. Then I spray it down with aerosol adhesive and store it under the downspout on the corner of my garage.
t0adman is offline
Old 02-11-2009, 02:37 PM
  #21
Denatured alcohol, or just run it quick in the snow and let it dry off overnight.
howtowakeakar is offline
Old 02-11-2009, 02:50 PM
  #22
Does anybody use automotive break cleaner?
Sylvain is offline
Old 02-11-2009, 02:58 PM
  #23
I use break parts cleaner and the air compressor.
Dvx400Rider is offline
Old 02-11-2009, 04:48 PM
  #24
scwrod's Avatar
I have a small parts cleaner tub and the hose has a brush on the end of it. Kinda Like this one but mine is a little longer.
I Just got it and it had kerosene already in it. The kerosene worked ok but it was not worth the smell. I filled it with WD40 and it works great. Cut my clean up time in half.
Someone mentioned earlier to use full strength simple green. I did that on a blue aluminum chassis and it took the blue off
scwrod is offline
Old 02-11-2009, 04:53 PM
  #25
sugelle's Avatar
Trader Rating: 63 (100%+)
If you use brake cleaner...make sure its non chlorinated formula. I normally use diluted Simple Green for all my cleaning needs in the garage and on my R/C cars. Stuff works miracles on dirt and grease. Just make sure you dilute it with water because if you use it straight it will remove anodizing.
sugelle is offline
Old 02-11-2009, 04:54 PM
  #26
scwrod's Avatar
now you tell me
scwrod is offline
Old 02-11-2009, 05:09 PM
  #27
I'm just starting nitro racing this year so I havent ever really cleaned a rig. What do you guys think would be a good beginner way of doing it? I was thinking just to take my engine and radio tray out and hose it quickyly. Then towel dry and spray all hinges and bearings with a shot of Wd40. Will this work? Also will the screws on my kit rust because of this?
rgrassey@me.com is offline
Old 02-11-2009, 05:11 PM
  #28
As long as you follow up with WD40, it should be fine.
(WD40 = Water Displacement [formula] 40)
Old 02-11-2009, 05:13 PM
  #29
Oh cool. So should I spray every screw with wd40?
Old 02-11-2009, 05:16 PM
  #30
Just spray everything with WD40
Alan D. is offline
