Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree138Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 03-16-2014, 08:25 PM
  #6361
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
He does not have a chassis sponsor?
Wildcat1971 is offline
Old 03-16-2014, 08:28 PM
  #6362
So again. Is MM 17.5 even worth the effort?
Liegh
I changed my order after reading and thinking about what I already know. To me it seems like you can dial in anything you need on the RM
for any track. I am soooo glad I changed my order to a b5. Maybe as time goes by the setup will prove the MM is just as good or better for 17.5. For the track I race on the most this seems like the car. I will try a mm at some point I know that.
Bubonic-X is offline
Old 03-16-2014, 08:33 PM
  #6363
Tech Prophet
yeah, I think I am going to give up on aspirations of MM. I will just keep dragging my motors across rocks and dirt lol. I dont think the MM cars will be set and forget cars, and that is what I really want.
Old 03-16-2014, 08:34 PM
  #6364
I havent won a race in awhile but this b5m killed it today by far the smoothest car i have ever diven and my gearing for my 17.5 is so on point.
xTotalghost is offline
Old 03-16-2014, 08:38 PM
  #6365
Trader Rating: 12 (100%+)
It probably wont be long
PFKAOG is offline
Old 03-16-2014, 08:44 PM
  #6366
Originally Posted by tropmonky
Impressive!
Regarding any hooking issues, I haven't had any hooking issues myself at OCRC. I'd like to get a set of flat front A-arms to try out since I'm just not sure how much it will change the feel of the car on a nice grip indoor clay track. After putting the Pucks system in my B5M I'm struggling getting the car dialed in again.
I sold my 2nd B5M (still in box) to a friend so I'm on the hunt for another one. If anyone knows of a place with them in stock please post it up here!
SRS had some yesterday
PFKAOG is offline
Old 03-16-2014, 08:46 PM
  #6367
Originally Posted by DKSPLIT96
I've owned both and just sold my 22 2.0 and kept the b5m.
Right on. Would you care to elaborate on this a little? Was your 2.0 mid motor? What key things do you like better about the b5m compared to the 2.0?
Dagolf is offline
Old 03-16-2014, 08:53 PM
  #6368
Jake S's Avatar
Trader Rating: 67 (93%+)
is where i am at right now with my b5m. car was really easy to drive a medium traction dirt surface. when the track is dry it becomes dusty and traction levels are drastically decreased, in these conditions i would run hubs forward to gain rear grip, at a minor loss of steering.
car was so easy to drive everyone watching said it just looked SLOW on my TQ run for the night (ahead of a few b5r, xfactory cubed, b4.2s and some losi 22 2.0s) with this setup it didnt feel like it needed to driven hard to be fast.
on another note, using the b4.2 jconcepts wing the holes are drilled 5mm-6mm back from the "kit" marks. played with it as far forward as the b4.2 kit mark, and as far back as 12mm from them, ended up with the best feel at 5mm-6mm range.
using a shorty in the 4mm from back position it just felt like the car didnt have enough rear grip on medium bite, car seemed to swing hard on mid-exit. using a shorty i think i would go back to the 4mm trail setting to smooth it out some, and add a 1mm spacer on the rear brace.
Jake S is offline
Old 03-16-2014, 09:00 PM
  #6369
Lance Tanner's Avatar
He had two this weekend, his dad and Randy Locken.... and Randy was also his radio sponsor I believe so Airtronics if you've got ears tune in. Or spend a little more time in AZ watching our 'up and comers' they have fantastic coaches.
Lance Tanner is offline
Old 03-16-2014, 09:03 PM
  #6370
Brollywood's Avatar
Trader Rating: 11 (100%+)
They don't do online sales as far as I know. Hobby express cincinnati ohio has the kits in stock. Call them. 513 248 4666. I was just in there. I told the about people wanting kits online. They said they are more than happy to ship the kits anywhere. Just a helpful hint to those looking. 4 were in stock and a slew of rear kits as well
Brollywood is offline
Old 03-16-2014, 09:11 PM
  #6371
Jake S's Avatar
You can google how to calculate the area of a circle.
The three smaller holes of the 1.4 x 3 add up to a larger hole compared to the 1.6 x2 total area
even tho total volume is larger, turbulent flow becomes the greatest factor in pack. because the holes are smaller they resist the flow of oil from bottom to top. volume flow is not pack, the resistance to flow is pack.
i terms of feel...for example, with a 1.6 piston in the b4.2 i ran 32.5wt in the front, with a 1.7 piston to get a similar on track feel it required 37.5wt to feel stable, but with a 1.4 piston and an additional hole the shock felt the best with a 35wt.
another way to show this is that in the b5m kit, it uses a 1.7 piston in the rear to use the same 32.5wt oil all around, while most people run a 1.6 with 27.5wt in the rear.
and i am not disputing that the 2x1.6 has more pack then the 3x1.4 as it also adds up to slightly more volume then the 2x1.7 as well anyway.
im most likely wrong. but oh well, its a forum not a text book.
Jake S is offline
Old 03-16-2014, 09:20 PM
  #6372
I don't understand why people are complaining about the rear of the car hooking or not rotating enough... simple fix.. tune your car in...
play with moving your rear camber locations, your wheelbase, your gearing, springs or shock locations and tires...
I am not at your track but try and see what one change at a time does to the handling of your car. then do another change and another until you are happy with how you want it to handle.
rickster is offline
Old 03-16-2014, 09:24 PM
  #6373
Jake S's Avatar
i knew what i would do to change it, i posted that, i also said it did it with a shorty, but when i went to a saddle pack and the same setup it did not...which is the battery posted in the sheet.
Jake S is offline
Old 03-16-2014, 09:29 PM
  #6374
Tech Prophet
Ouch, Sponsored by Randy......He is Mr Friendly Himself......
Old 03-16-2014, 09:58 PM
  #6375
STLNLST's Avatar
Trader Rating: 32 (100%+)
TQ of 17.5 was a MM car so both can work. We have proven time after time that MM works on both low and high bite. Don't believe me....the TQ was from LSR in Sacramento which is low/med bite. It's a personal preference and from what I've seen/read some would rather be told a set up rather than test some things out. The winner of Superstock also from LSR.
STLNLST is offline
