Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
#1381
It won't effect steering, but the gears for the diff are plastic. Run too tight of a slipper and you'll be changing gears out a lot. Ask xb4 owners. Hopefully Kyosho will come out with steel crown and pinion gears. I bet that by the time they finish up the center gear diff they will move all gears to steel.
#1382
UMW708 is a sway bar kit for the RB6. I used the bulkhead on my RB6 and everything else on my ZX6. The sway bars are to long so you need to trim there length.
#1384
Good thing is that the 1.4 sway bar is included in the kit. copy paste from Amain.
•KYOUM724B Kyosho Rear Bulk Head w/Sway Bar Mount (Mid Motor)
•KYOUMW708-01 Kyosho Stabilizer Link Set (Mid Motor)
•KYOUMW708-11 Kyosho 1.1 Stabilizer Bar (Pink) (Mid Motor)
•KYOUMW708-12 Kyosho 1.2 Stabilizer Bar (Red) (Mid Motor)
•KYOUMW708-13 Kyosho 1.3 Stabilizer Bar (Orange) (Mid Motor)
•KYOUMW708-14 Kyosho 1.4 Stabilizer Bar (Yellow) (Mid Motor)
#1385
sway bar kit
Is there a difference between the RB6 and the ZX6 sway bars?
#1387
Where did it push, going in, middle, out? To me, when you tightened the front diff it would make it push more going into the turn but when you removed the front bar that balanced out the change to the diff.
I am still running the kits pistons, springs, and bar but a hole at 18mm for the lower shock mount. Mine would push going in and in the middle of the turn. However, my front diff nut must be going bad because now that became a little loose and my car is better, not great but better. The shock lengths are what he has listed on his sheet.
If you get bored sometime and want to try something different give Chris Nelson's setup a try. It is pretty darn good around these parts.
#1392
I have been running Tebo's Reedy Race setup, with a longer rear link. Car is hooked up pretty good. I ran my ball diffs somewhat loose but i actually tightened them down to like a md tight feel and the car drove a lot better. I tried the gear diffs but feel the ball diffs just feel better.
#1393
#1394
I'm beginning to feel the same way. Run the bLl diffs til fried before switching. I have a pretty good knowledge of how to tune gear diffs to exactly what I want to the car to do, so it shouldn't be that traumatic to switch how are you liking the 4PX? I had the PKSR but it went up in smoke when the rechargeable battery freaked out.
#1395
just have a quick question about toe been running the car for a couple of weeks and its really good! just confused a little bit on how to get a little more toe in the rear i was looking at the toe chart and to me using the EE bushings will give me 3.5 degrees of toe just want to make sure I'm looking at it correctly before i go ahead and put them on
thanks
thanks
