School me on nitro motor maintenance for racing.
#16
hey
#17
I run dollar bearing for everything, I spend about 60 a year in all bearings. I run Dyn Max life 4 shoe clutch shoes, one set last me all summer. i do change the springs once in awhile. As far as my engine go, I don't do nothing, especially if its running good, make sure I have good clean filters, make sure my EPAs are set good and make sure its a DBC EVERYTIME.
#18
Enjoy it, set a budget for yourself, and try to stick to it as best you can. Worrying about how much money you're burning every time you run your car will suck all the enjoyment out of it!
#19
what springs are ya'll running on the losi 8ight t 2.0 with dynamite max life clutch? I run on a red clay hard pack DUSTY track. Usually use soft ibeams.
#20
Keep your air filter clean and check over your clutch regularly and your should be in good shape. if you question a bearing change it, dont want a $1 part taking you out of a race.
#22
Ok I understand clutch and clutch bearing maintenance but what about these? How often are these replaced?
Engine Bearings
crank
piston/sleeve
connecting rod
Engine Bearings
crank
piston/sleeve
connecting rod
#23
VERY IMPORTANT
make sure your piston is DB after every run.
#24
You replace them when you need to, if it makes financial sense. When that is depends on you and how you run your engine. I have a 12 gallon Werks B3 that I bought used on all original parts. It's a backup engine now. If anything wears out in it I'll just replace the whole engine with a new one as it would cheaper than repair.
#25
it's time to replace p/s when the engine won't hold a tune.
To check on the crank and the connecting rod you have to take apart your engine and check for slop in the connections - some
people do this regularly some don't. The bearings are only a concer if they are leaking excessively. But tu be honest, most people consider the 454 to be a disposable engine.
#26
Oh, if you're worried about how much you're gonna spend, you're in the wrong hobby. If you're racing, don't forget about those $60 a set buggy, or $80 a set truggy wheels / tires that you'll go through in a few race weekends, with practice. There's also air filters, glow plugs, fuel, etc....
There are ways of cutting some costs as far as engines go. Pick a relatively inexpensive engine(such as the Werks B5) and take good care of it. Break it in well, change your air filters often, keep your tune in check, run good fuel, etc... Just doing those things will make your engine last longer and in turn save you money. You can get quality glow plugs pretty cheap(such as Odonnell plugs). Again saving money. I personally suggest running a lower nitro content fuel such as 20% fuel. That will not only cost you less as far a buying fuel is concerned but will also give you a bit more longevity out of the engine. I run Odonnell 20% fuel in all of my engines and don't get beat down the straight by anyone. Don't fall for 30% fuel. It's not needed or doing you any good.
Last thing, don't rebuild engines. It's not worth it. In most cases you will pay as much or more to rebuild an engine than you would to buy one new.
#27
Yeah i will get a new motor after the 454 is dead. I pretty much agree on the no rebuilding but i guess i'm just wondering if a part in the motor goes bad at like the 3 gallon mark it seems to make sense to replace that part since the motor isn't dead yet.
Are are some other good racing motors in the 200 to 220 range?
Thanks for all the help so far.
#28
So keep new air filters on it regularly, follow all of the other advice like BDC when you shut it off and after run oil if not using it for a couple days. Then what you should do is when it won't hold a tune good anymore and you suspect the piston/sleeve is worn, check all bearings and the rod to crank fit and if it looks like it is in good shape get the p/s pinched for $20 you have a good backup you are familiar with that will run good again. My $0.02. Many have told you to just leave it behind but you never know when you might really need it or want it for something and this way it's financially makes sense to "rebuild" it. It sounds to me like you really don't want to just chuck it so consider pinching.
In short - Yes, there is a part that makes sense to replace - but you shouldn't have to spend the money on new p/s. Get it pinched!
#29
i don't see how people still say electric is cheaper. No way! The price of engines, plugs, clutch bells, clutch shoes and springs/bearings, flywheels, Con rod and bearing replacement, fuel, glo ignitor, starter box, starter box batteries, tunned pipes, aro, pipe manifold springs and gaskets, air filters, air filter oil, air filter necks, engine tools and screws, heat gun, engine sealant, temp gun (use this for electrics to).
On an on and on and on. Not to mention P/S maintence and replacement.
and if you are real good and you can get it to run really well and have it last more then five gallons. Your a pro
#30
