Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 11-22-2015, 01:31 PM
  #1651
Motorman007's Avatar
Trader Rating: 89 (100%+)
Originally Posted by schirmann433
I'm running an B5m now and I had that same problem with it pushing I went with 3-hole 1.4 tapered Pistons taper sid down, kyosho springs gold in the front and white in the rear. I turned the rear camber mount to where the -2 is up then put 2mm washer under the ball stud. Then I have the aluminum rear hubs and put 3mm washers under that ball stud. Make sure the front axles are moved back and the rear hubs in the middle.
Thanx sir I will try this..
Motorman007 is offline
Old 11-22-2015, 01:49 PM
  #1652
schirmann433's Avatar
Trader Rating: 11 (100%+)
I'll work on posting a setup sheet later on this evening
schirmann433 is offline
Old 11-22-2015, 02:21 PM
  #1653
LiL CeeZ's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Motorman007
Was your yokomo the Y-Max or the Laydown stock yokomo.
We both did the Laydown tranny and your right the stock yz2 will not traction roll.
Our track is not high bite. If it was we would run the Laydown tranny.
We have tried the SMC weight and change stuff still didn't work lap times wise vs the conversion like Lee Martin Y-Max.
When we go to a high bite track the good news is we can change to the Laydown tranny and be money.
Thanx for your input sir. Wonderful.
How do you feel about the shock rb6 shocks vs the yokomo?
I have a Ymax as well but still haven't had the need to run it at my local track because the laydown is the business.
The RB6 shocks are great but I don't think Yokomo is that far behind if at all. Here's my take, things get overly hyped and then others that have said item join in on the band wagon and it snowballs. It's really hard to find non-bias analysis nowadays for anything and especially in such a small niche market as RC cars. Kyosho springs are one of those things, they are good springs but for the money I have found stuff I like just as much for cheaper. Kyoshos shocks are excellent though. I know this isn't the answer you were looking for but it's really all subjective.
I have a heavily upgraded RB6, tons of money in this thing. It weighs just above legal limit and has everything you could ever want to have on it. it's much tougher to drive comparatively, and that's after tons of tweaking and testing to get it dialed. I've spent hours at the track practicing and making small changes to make this car run like I want it and overall it does but the box stock set up on the yokomo without doing anything extra is spanking the RB6 on high bite and it's not even close.
Put it this way, I got off work early one night and went to the track to put my electronics in the Yok. Track owner took one look at the car and said, "This is a good car, you can tell right away." Soon as we finished I put a battery in it that was on a storage charge () and took a few laps then passed my radio. He drove it and was amazed, now hes seriously thinking of carrying the parts and a couple kits! Charged up 2 more batteries and ran them, that was on wednesday. Raced yesterday, only 2nd time driving the car. Smoked my laps times with the RB6. Car works for my driving style, may not be the same for everybody else.
RB6 race results same track same night of racing for both cars
Yokomo YZ2 (non Ymax)
The proof is in the pudding..
Expert lap times on this track are mid 15's to low 16's
LiL CeeZ is offline
Old 11-22-2015, 02:52 PM
  #1654
Lil ceez you are right laps times don't lie.
Good job.
Wonderful info sir.
The whole reason we got the yz2 bc we was told our track that just got built 7 months ago was going to be hard bite and it is not so we are adapting to the situation. If we get a high bite track yz2 stock is money.
Old 11-22-2015, 06:06 PM
  #1655
Originally Posted by pumpkinfish
I have been running the buggy on med-med/high bite clay and it is very easy to drive. Once I got a neutral setup on the buggy it felt a lot better. Now if i could drive better it would be unbeatable! I will say at this moment, I have been doing better with my YZ-2 than i ever did with the B5m.
What pinion should I use if I'm going to run a 7.5T motor
Old 11-22-2015, 06:07 PM
  #1656
suby723's Avatar
Trader Rating: 21 (100%+)
24t
suby723 is offline
Old 11-27-2015, 07:31 PM
  #1657
Does anyone have Futaba servo horns for the yz2 I can buy from.
Old 11-27-2015, 08:57 PM
  #1658
Hey Guys,
I just took the plunge on this buggy. It should be delivered in a few days. I will be running it on a small indoor carpet/oz ite track with 14 second lap times. First has the arm problem been fixed? Has anyone tried boiling their arms?
Does anyone have a setup sheet for a similar track? https://youtu.be/WCly52_n-Ds
Are there any build tips for an experienced racer? Pitfalls to look out for?
Thanks in advance....
SouthFloridaApp is offline
Old 11-27-2015, 10:30 PM
  #1659
mes
I haven't heard of any arm problems on the YZ-2, do you mean the YZ-4?
mes is offline
Old 11-27-2015, 10:38 PM
  #1660
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by SouthFloridaApp
Hey Guys,
I didn't read all of this but I have the kit arms, my kit is a month old and zero issues so far About the same size track for me but we are on turf Don't over power this car w/ too big of a motor, on that small track you may want a well setup 17.5. I like those shims to raise the trans a bit from http://mckunedesign.com/parts/yokomo otherwise it's a pretty solid build, I don't recall any issues. I like the shocks on the rear of the tower best.
8ight-e is offline
Old 11-28-2015, 03:18 AM
  #1661
Default Turf setup?
Anyone have a good turf or carpet setup they are willing to share?
chvtec33 is offline
Old 11-28-2015, 03:19 AM
  #1662
Default Gearing
What is a good starting point for gearing with a 17.5? Smaller track.
chvtec33 is offline
Old 11-28-2015, 05:39 AM
  #1663
Trader Rating: 54 (100%+)
petit rc has a few
rkhess is offline
Old 11-28-2015, 07:20 AM
  #1664
8ight-e's Avatar
72/32 for most motors, if it's higher RPM not low torque maybe start with 30t pinion instead.
I don't have a full setup sheet filled out, is there something specific w/ setup or looking for the whole thing?
8ight-e is offline
Old 11-28-2015, 09:37 AM
  #1665
I'm running 69/33 on a smallish clay track.
afm223 is offline
