Cityblock VS. Calibers
#31
I would like for a magazine to do a blind comparison where they put an average driver on the stand and let him get used to the track and the buggy/truggy and switch the tires to where he can not see which is which and completely run through all of the tires and see if he can tell you which is which?????? I know that tires make a difference but I think the higher the level of driver the more important it becomes, I would love to conduct this test if any tire co.'s out there want me to do a review send me a p.m. please don't try and prank me.... I have certainly asked for it.
#32
good idea sounds good insend of having a pro driver test them
#33
#34
One and only "test" of tires is lap times. Just because they "fell good" or "feel fast" doesn't mean that they are.
Out of the 100s of tires we've tested it always comes down to what feels good is usually the slowest in lap times because the driver becomes comfortable and doesn't stay on the edge and thus slows down.
#35
Hmmm.
What feels wright is getting traction over different parts of the track and not having to buy so many different tires for wet or dry, loamy or hardpacked tracks. The Cityblocks fit the bill. I can use them in loose wet dirt and they work all the way down to fairly hardpacked conditions. Then I switch to pro line revolvers. Both tires last long and I'm not looking around trying to find another tire. When I slow down and relax my laptimes get better while everyone else is wrecking, I'm cool calm and in the lead or close. In a 20-40 minute main it all comes down to staying relaxed and yet pushing yourself without going too far. So feeling is important. you say some silly stuff Jimmy. Are you a tire scientist?
#36
When I slow down and relax my laptimes get better while everyone else is wrecking..
No he is not a tire scientist, but he knows what works on the track. He knows and deals with a lot of people in the rc tire industry. I'd rather gain knowledge from someone with real world experience over someone sitting behind a desk.
Back to the actual thread topic, I like cityblocks. The revolvers work nice too but they wear a lot faster. City blocks work in most conditions. My only gripe with them is that sometimes they have too much traction for me, but instead of a tire change I will make a small setup change to compensate...then there dialed.
#37
So true.
The city blocks are really locked in, and I was thinking that in my 808 it would help to loosen up the rear, hehe, in my car. Maybe 2 degree rear toe in instead of the stock 3. That would let the car rotate better in the turns. But heck it's so stable now that I use a little more rear brake bias in the one or two turns that it's really not necessary. I set my car up to give more steering anyhow. 10,000 center diff oil helps a lot. If the track gets grooved in, not blue, just packed down an loose dirt pushed aside it will free up the rear, but still it pushes in a few weird places. Any ideas? Zero defect had an idea to raise the front inner camber location to give it more turn in, that was clever I thought, or I thought leaning in the rear tires from 0-1 to 2-3 degrees negative might help too. Or moving the rear hubs to the rear so more weight is put on the front and lighten up the rear, not my first choice, but an old trick that can work. But your idea to change the car while leaving the tires alone is a good one, thanks.
#38
oh yea i see what mean i run 3 degree toe in in the rear on my eight 1.0 b
and it doesnt rotate as much cause its more stable
#39
Does anybody know if the calibers for the truggy are ROAR legal?
