Ideas for offroad car to break in .12 TC engines
I was wondering if there was a decent offroad (10th 4wd nitro buggy?) car out there that used the PS style cranks (iirc that is what the long onroad style cranks are called), rear exhaust, that also uses a slide carb out of the box. I am hoping to find a basher car that I can use to break in my nitro tc engines without having to go to a track (where I live I can't really run touring cars except at the track). The Asc gt2 uses the proper crank but is designed around a rotary carb. Any ideas would be great. I have looked a bit but haven't found anything that would work without tons of mods.
Cheers
Cheers
so ya "not" talking about the sg crank ya talking about the short crank .. i was gunna say the JAMMIN crt.5 1/12 truggy is wat ya want but it uses the sg crank . that .12 engine is slide carb , pullstart and rear exhaust .
i have a losi xxx-nt that runs a slide carb and rear exhaust plus a touring car header and pipe .. setting up the slide carb is very easy you just have to turn the carb slightly and it will work with the right linkages .
I have a break in stand. But even with a break in stand it still takes more fuel to properly runnin an engine. The stand just eliminates most of the grunt work.
I have a xxx nt and the crank style is wrong for touring car engines. My NT has m5 x0.8 threaded crank.
well my xxxnt has a jammin .12 "SG" crank engine , i was gunna buy a sts on-rd race .12 but already had this one . .. all i did was buy a set of .12-.18 smallblock adjustable engine mounts from ebay . i run a traxxas revo flywheel and clutch bell "which is 32pitch same as the xxxnt" . move the engine back on the mounts to where ya want it , only 2 holes in the chassis slots will line up to mount it , bolt the 2 up , then drill and tap 2 more holes in the mounts through the chassis slots . so its like stock . with 4 mounting screws. the engine will sit out further but , for what u want it will be ok .
Happen to have a link to the company you bought the mount from?
im in OZ and i did find them 6months ago in OZ ebay .. cant find-em now but if i do il PM ya ... they look like these , but these are for the .21big blocks . dunno if they will still work prob not ..
http://www.ebay.com.au/itm/OFNA-1705...#ht_1801wt_905
heres a pic of mine with the .12 SG and on-rd header and pipe .. as ya can see it does sit further out but it still handles fine .. its not the best pic to see how its mounted i can take another one if ya want close up .. i gunna buy a NINJA on road .12 pipe next for it ..
ok found a pic of what i bought them for and the engine on them ... a kart project i did .. heres what they look like ..
Go to the manuals section on the Team associated web site and it tells you how to cut down the SG crank with a dremel to make it into PS style
but im pretty sure he needs the SG crank for his ON-RD cars , all he wants is a off roader to run in the engines .. so he cant cut down the crank ..
adjustable mounts
