Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
GT8 Class--buggy-based on road electric! >
Like Tree17Likes
Old 12-21-2011, 10:12 AM
  #2911
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by SNR Graphite
Why are you charging only at 4amp. A 5000mah pack you should be charging at 5amp.
The charger I have can only charge 3s & 4s packs at a maximum of 4A. For everything else it can charge up to 6A.
YR4Dude is offline
Old 12-21-2011, 10:14 AM
  #2912
YR4Dude's Avatar
Default Mechanical vs. Electronic Braking
Which do you prefer and why? Advantages and disadvantages of both.
YR4Dude is offline
Old 12-21-2011, 12:43 PM
  #2913
J-milz's Avatar
Trader Rating: 42 (100%+)
Do you do the machine work yourself?? I need someone to machine a 2speed diff housing for a Losi 8ight GTP.
J-milz is offline
Old 12-21-2011, 01:42 PM
  #2914
Micro-E's Avatar
Originally Posted by RC Passion
Ditto!
How u been Erik?
Busy, man.... really busy. Working some weekends, and now that my kids are off school, find myself playing airsoft when I should be racing cars!!!
lol! S'all good. I'll be back on the track in late Jan.....
Micro-E is offline
Old 12-21-2011, 04:03 PM
  #2915
Yes, I wanted to make a motor mount, the way I wanted, cost me 2k,but
I did it myself, first time using a milling machine, I've done some lathe work before,boring the hole for the bearing is the hardest part, everything after
that is easier.
Joat is offline
Old 12-21-2011, 04:06 PM
  #2916
Go for a 2050 or 2250kv motor! Anything more you'll be plowing thru the end of the straight! I've seen some do this even in an almost 200ft straight! I wont name names.... Not a pretty site!
Yeah thats what I was thinking, haha. I have no experience with 1/8th scale stuff, is there any one go-to motor? Or maybe just one to avoid?
Stregone is offline
Old 12-21-2011, 04:27 PM
  #2917
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
I like the Tekin 2650 running it in sensor mode is the way to go. It makes it a lot easier drive.
SNR Graphite is offline
Old 12-21-2011, 11:14 PM
  #2918
RC Passion's Avatar
Mechanical, you'll gain brake bias and if tuned right, it'll out perform motor braking. Front brakes generally require more braking force vs rear.
RC Passion is offline
Old 12-22-2011, 10:51 PM
  #2919
Was gonna do some test runs after I reassemble her, went to charge my TX pack and noticed it puffed
Joat is offline
Old 12-23-2011, 10:33 AM
  #2920
Raman's Avatar
Trader Rating: 94 (100%+)
You should add some weight to that car, like 5 lbs to make sure it stays on the ground
Raman is offline
Old 12-23-2011, 12:13 PM
  #2921
She's pretty heavy, the chassis came like that, old skool 4mm cnc ofna option
Joat is offline
Old 12-23-2011, 08:45 PM
  #2922
Vision's Avatar
Trader Rating: 41 (98%+)
Joat, that looks amazing!. I like how you have that cf top plate to tie the chassis together for more rigidity. Do you think those pieces would fit a dm1-sped ?. Would love to get something like for my dm1.
Vision is offline
Old 12-23-2011, 09:04 PM
  #2923
Probably not, the orginal gtp's where setup like that, it is stiff, even with my cnc 4mm chassis there alot of flex, the newer ones have the braces to the chassis and I know theres got to be alot of flex,dont know why they changed it, if I had one or an exact copy of the mounting locations / clearence to items I could do it, but SNR would be better for it he has cnc, mine is basically hand cut on my mill.
Joat is offline
Old 01-06-2012, 09:53 PM
  #2924
I'm almost finished with my hot bodies ve8 setup, but have a question. I also have a slash....are most gt8tracks allowing them to run with the big gt8's? How are they being motored/geared/classed?
txaggie08 is offline
Old 01-07-2012, 12:37 AM
  #2925
RC Passion's Avatar
The slash would be categorized as GT8 lite and if enough lites participate, they should run separately, if not, then together w/ the regular GT8'S. Motors are still open to keep the classes easy to enter. Gearing for GT8 lite's really depends on what motor you plan on running and how much speed and runtime time you want to get out of it. You just gotta watch those temps! Good luck! Post some pics up of your ve8 if u can!
FYI,
OC Circuits next GT8 race is @ hobbytown usa Corona, Ca Jan 15th! Who's ready?!!!!!
