how do i get a front bearing out?
I use a bearing puller made by JP racing. But there are several ways to do it. Heat the block up by the bearing with a heat gun, place it on a hot plate and heat it up, put it in a small frying pan and heat it up, put it in the grill or oven and heat it up. Just get the case hot enough and it should about fall out. May have to give it a little tap but it should come out pretty easy. The rear bearing may also come out. Just make sure you have some good gloves on and put the bearings in before the block cools off.
OFNA Bearing Puller Kit for 13mm and 14mm cranks
[OFN10798] for about 55 bucks
btw with this tool you dont need heat for front bearing its not as tough as rear bearing
hold the crankcase and make sure the tip of the glow plug wrench makes contact with the front bearing from within the crankcase. Hold the crankcase and the wrench together and tap/whack/slam it on a wooden chopping board
I put crankcase engine mount in a vise, heat up with my mac heat gun and tap bearing with a small wood beam with hammer. done many this way, take your time and turns out fine
frezze the new bearing heat the block up and back the bearing out with a wood dowl
Here is a couple vids for using the heat method. He uses airplane engines, but it's all the same.
Part 1
http://www.youtube.com/watch?v=TuzEco3EDUM
Part 2
http://www.youtube.com/watch?v=OLSoXPLGzOI
Part 1
Part 2
The GRP engine tool works like magic it is so easy its like cheating. If you have ever pounded a bearing out with a wooden stick and hammer you will appreciate this tool. Front bearings dont last forever and need to be replaced when they leak. I recently replaces the front bearing in an OS speed and after I gor the engine tore down it took less than 5 mins to pull the old bearing and insert the new bearing. I love that tool. I know its 180 bucks but its worth its weight in gold.
if it is in your budget (save up for it ) get one the right tool makes it a
lot easier and you will not put off changing them a oven mite and a stick
are not the right tools
