#8298
Hi All!
Another day another round of questions...
I have found a lot of battery info, but I cannot find any solid advice on what the best battery mAh rating is for racing in stock (novice to start). I don’t want more power than I need (i.e. cheaper the better)
Motor/ESC… not sure where to start. As noted, I will run stock. I can upgrade later if I decided to run mod. What are some good recommendations for motor/esc combos?
Turnigy has inexpensive motors and ESCs. Would you guys recommend them? Can get both for less than $100!
http://www.hobbyking.com/hobbyking/s...approved_.html
ii. http://www.hobbyking.com/hobbyking/store/__22402__turnigy_trackstar_120a_turbo_sensored_bru shless_1_12th_1_10th_esc.html
I understand the ESC needs to have a low voltage cutoff, but I could not tell if this ESC has the cutoff feature.
Or would you recommend something a little higher in price? I found some Novak and Tekin combos that look decent. Would like to stay under $200.00 (preferably even less).
Thanks for any advice!
#8300
seems that bk was running an unusual rear wing at cactus...jconcepts prototype??
http://events.redrc.net/event-galler...c/?nggpage=10#
#8301
I run speed passion, can find there Reventon r or pro 1.1 for good prices. the pro is great, the but the R model has a boost feature/ still runs blinky (stock class). and can handle most mods. can find a ESC motor combo for around 100 bucks. (can order directly from there site).
Also the Speed Passion are ROAR race legal. do not think the Turnigy are as of now.
#8302
The best bang for your buck esc/motor combo that I also consider really good is the Hobbywing Justock ESC and the Reedy Mach 2 17.5 motor. Perfect place for you to start in stock, the esc is blinky only so you wont need to mess with boost or anything. The esc is about $50 and the motor is about $90. Better quality than any hobbyking stuff also.
ESC: http://www.falconsekido.com/products...c-blue-edition
Motor: http://www.amain.com/product_info.ph...ess-Motor-175T
#8303
Hi All!
#8304
http://www.amain.com/product_info.ph...Wing-66-Wide-2
#8305
#8306
Hi All!
http://www.hobbyking.com/hobbyking/s...arehouse_.html
http://www.hobbypartz.com/98p-60c-42...se-shorty.html
http://www.smc-racing.net/index.php?...product_id=127
Personally I run the SMC.
For ESC/Motor combo have a look at SpeedPassion if you're on a budget. $70 for the combo is tough to beat. http://www.speedpassion.net/us/produ...SP000202&c=CMB
Alternatively just get the ESC http://www.speedpassion.net/en/produ...SP000048&c=ESC and the R1 Wurks which seems to be the hot 17.5t motor this week. http://www.reflexracing.net/R1-Wurks...r-_p_2186.html
#8307
