how do i stop the front wheel lifting up in a turn?
i have a problem where my off road car's front inward wheel lifts up in a hi speed turn, usually flipping it over. e.g. if i turn left a just 3/4 throttle it will lift up the front left wheel and balloon it. is this down to the wheel ballooning or do i need to adjust the camber and tracking.
thanks for help
thanks for help
-Less front droop
-stiffer springs
-stiffer sway bar
Are you running on pavement? Offroad car + pavement = traction rolls.
-stiffer springs
-stiffer sway bar
is it traction rolling mate you also said balloning
so for traction rolling id lower rear roll centre
also try going up in front diff oils and centre maybee
there is no sway bar. but i will decrease the droop and see if that has any affect, also could camber be part of this?
what front diff oil do you recommend for racing (getting into it)
U should deffinently have sway bars on... If can't get swaybars, shorter and lower inner camber links will prevent body roll.
i am running a Carson (Tamiya) specter
goo.gl/gUIrT <link to the product page
looking for a sway bar now, will have to look on ebay.de tho so min price is 20 pounds
You can also try stiffer rear springs and sway bar to keep the weight on the front.
A heavier weight diff fluid in the front might help too, if you have a front diff that is
