TLR SCTE 3.0 Thread
#391
I'm the dumbass? Your the one that failed to realize what he was telling you was actually being honest and not go telling you to buy alum upgrades for the 3.0, he was doing the exact opposite of what you accused. Not like he has control of them changing C blocks. But I'm the dumbass...also says the guy that calls me a "pinhead" what is this 1988?
Leave the forum's buddy, no one's too concerned.
#392
Updated CVD bones
How do you know if you have the updated CVD bones? The New one has a flat spot on the diff cup end. Old one is rounded. They provide for sharper turning because the bone is smaller under the CVD ball end where it would rub the inside of the stub axle. Small change = improved steering.
#393
same with the Ti turnbuckle kit
#394
Tech Prophet
Your forgetting the part where you were telling Casper he was basically just sticking up for TLR because he is a "factory guy".
Thanks.
#395
He will need another pack of 4 - 40 by 5/8 button head screws for the body post that tie onto the shock Tower also the protek it also does not have the two lower screws to tie the rear gear box case I had to get those screws from Lunsford and I could only get them an inch and three quarters instead of an inch and seven eighths
#396
Also used a turnbuckle that goes between the Servo arm and Servo saver it is a Lunsford 3.5 millimeters by 24 millimeters I had to sand a millimeter off of each turnbuckle end
#399
Bad springs on SCTE 3.0 shocks
Spring mystery solved. 3.0 kit springs were sagged out. I put the new Red springs on and immediately could see it was better. Collar at the bottom of threads, but ride height is at 27mm RTRace. Plan to use the +4 spring cups if needed to maintain ride Height.
I thought about this for a while and devised a crude way to compare springs using a digital scale. I compressed the springs to 45mm and took a reading in grams of spring pressure. See results below:
Compressed springs to 45mm
Kit Springs
#1 720g
#2 670g
Replacement springs
#1 820g
#2 830g
Just bad springs. Look forward to track day. Now I can make other setup adjustments.
Kit Springs
#1 720g
#2 670g
Replacement springs
#1 820g
#2 830g
#401
Kit Springs
#1 720g
#2 670g
Replacement springs
#1 820g
#2 830g
Kit Springs
#1 720g
#2 670g
Replacement springs
#1 820g
#2 830g
#402
I finished my kit on Wednesday of this week and ran a few practice laps with it last night. My kit has the same issue with the low ride height on both ends. I'm at the very bottom of the shock body threads and I'm getting only 25mm of ride height. No worries though, the stock rear red spring is too soft for indoor clay anyway, so I'm going to pick up a set of orange and silver springs for it. The stock red spring may be good for a looser outdoor track, though. Other than that, the kit set-up was really good on my local clay indoor track. It wanted to jump a little nose down at times, but I think that is also an issue with the rear of the truck being sprung too soft. The nice thing is that unlike my old Tekno SCT410.3, I can pull the nose back up with some extra throttle. This kit seems to be very responsive to throttle in the air, very controllable.
#403
No, but you should not need them for axle. I have made some for a different scenario. Only time I needed spacer for axle was using Tekno axles with aluminum carrier on rear. Tekno axle kit does not work well with aluminum gear box inserts or rear hubs. Don't need Tekno stuff on this truck now and don't need aluminum hubs or uprights either. both have been updated and so far proven strong.
#405
