New fuel?
#16
70 synthetic
30 castor
30 castor
#17
Just ask anyone of my sponsored drivers
#19
Cold Fusion is a PROVEN winning fuel!!!!!!!!!!!!!!!!!!!!!
#20
BigAlz why are you confused? The question was is coldfusion fuel, "pure castor or synthetic?" Cold fusion fuel is not pure caster nor synthetic. It is a mix of 30/70.
BigAlz were are you from? and what and were do you race?
Hope this helps you man. Good luck, try it out and you want go back to what your running now.
#21
He said neither because it is not 100% Castor and not 100% synthetic. It is a blend.
I switched from GEN2 over to Cold Fusion and I like it better. I used to use Trinity and liked it, went to Gen2 and temps did drop like there adds say, then tried out Cold Fusion and the temps dropped even more and had to lean out my motors more. I think the product is top notch. 4 people in my area I race with switched over to after trying some out.
#22
but. i live in louisiana,and run a rc8t with a rb s5.. i use 25% gen 2.
#23
I have
30% nitro
20% nitro
all depends on oil package you want
30% nitro
20% nitro
#24
If you make it to the www.wiregrassindoornationals.com there will be a lot of racers running this fuel. I run a RB S7 with cold fusion fuel, If you want to get some of this fuel I will send you the Shim so you can run 30% in your motor also. My run times are great and temps stay very low, I get over 8.5 min with a fuel sucking JP-1 pipe, and my temps stay below 230 and cant ask for any more power out of my motor.
#25
there will be alot of sponsored and non sponsored drivers at the PNB in Feb running Cold Fusion Fuel.
email me if you have any further questions
[email protected]
thx
Vernon
[email protected]
thx
Vernon
#27
#28
i wanna race:
Hope this has cleared things up for you, if you have any more questions please ask.
#29
I also ran O'Donnel before going to Cold Fusion if you run it and give it a try I dont think you will look back. It is very consistant and predictable. I live in North Florida very hot and muggy and have had no problems. I have also got about 2 gallons through a V-spec that I also ran O'Donnel in and it is still ripping internals look good no grime or build up.
#30
WOW
I am away a few days and look what happens
I appreciate the input,looks like guys have faith in this fuel
I am gonna buy some Cold Fusion and zooooooooooooommmmmmmmmmm!!
