what would cause a engine to burn all it's fuel no matter how rich the settings? >
Old 04-10-2010, 03:35 PM
Default what would cause a engine to burn all it's fuel no matter how rich the settings?
Now matter how rich i put the settings on my picco .26 outlaw it burns it all. And is running over 300 degrees. Of course half of the piston skirt is broke off
does anyone know the correct head shimming for this engine?
dreaux is offline
Old 04-10-2010, 03:53 PM
Tech Prophet
tc5 man's Avatar
sounds like you have a leak somewhere man, if its 300 degrees and its tuned rich than there is a leak .
tc5 man is offline
Old 04-10-2010, 04:00 PM
Trader Rating: 47 (100%+)
What do you mean "burns all it's fuel"?
Man, you sure do have alot of problems
with nitro engines.
rageworks is offline
Old 04-10-2010, 04:06 PM
no man no no. It's cool buddy!! This was a old busted engine with a busted up piston. I replaced the rod. It is ment to punish. All my other engines are race engines.
Air leak huh? doesn't really matter. I do not care about this engine much.
it is an expieriment!!! i was having fun!!!
da da dadadad da da da fun fun yipppeeee!
dreaux is offline
Old 04-10-2010, 04:10 PM
portyansky's Avatar
Trader Rating: 54 (100%+)
If it doesnt really matter, why make another thread? Do you even race? It seems like you like to tinker with the engines more then you like to race. You do know even you have the fastest baddest kick ass engine in the world, you still have to know how to wheel it.
portyansky is offline
Old 04-10-2010, 04:15 PM
Lilja's Avatar
Like people driving around in Ferraris knows how to use them properly? Or even ever tries?
Lilja is offline
Old 04-10-2010, 04:18 PM
sorry. Look, yes i race at my local club and yes i want this motor to run when i am not at the track so i can save my better engines for the track. This was the first nitro motor i ever had and it threw a rod. When it did it broke parts of the bottom of the piston off. It's not scratched, bearings are good and so is the crank. SO i put a new rod in.
But it over 300 degrees and would like to get some imput that''s all. No harm done. Yeah i don't care much for this engine but i still want it to run right. I am going to resleeve it too.
My local track just closed as well. He won't have a new one till the end of may
dreaux is offline
Old 04-10-2010, 04:52 PM
disonect both fuel lines pinch one withur finger and blow into the other one, i bet u got a leak in ur tank, that there will make it run real lean, most of the times it would be a cracked tank or bad O ring on the tank lid, first place i would check before checkin for air leaks on the motor
skidoos is offline
Old 04-10-2010, 05:05 PM
good thinking skidoos!!! think i will try it. but i think i will plug one end and submerge the tank in water then blow.
dreaux is offline
Old 04-10-2010, 06:58 PM
Trader Rating: 49 (100%+)
What is ur first name?? Don't ever remember meetin u at action, and I am there REGULARLY. So......
cleblanc is offline
Old 04-11-2010, 06:50 PM
kersplat's Avatar
Default Engine
Where is the piston broke? If it is the lower skirt and it is on the exhaust port side, that is where your fuel problem is. When this happens and the piston is at TDC, the fuel charge in the crank case is vulnerable to being lost out the exhaust.
kersplat is offline
Old 04-11-2010, 07:15 PM
yeah man. It's really a messed up engine. When the rod blew it blew out parts of the piston on two sides. I know it's the crankcase volume/timing that is doing this and its ok. It still screams and stays around 260 so it's ok. I have to hike my endpoints on my throtle just a hair to let it idle right. Can use the idle screw because i have to be able to control the ilde so it won't die.
I might resleeve it. Or i could just get another motor for my other buggy.
I am surprised that it even runs at all.
dreaux is offline
Old 04-11-2010, 07:23 PM
Madbrad's Avatar
Trader Rating: 30 (100%+)
Sounds like its time for a new motor. Even replacing the piston and sleeve still leaves you with used bearings and possibly a warn crank shaft pin. With most budget motors in the $100-$150 range it might just be a better idea to pick something elese up then keeping this one going.
Madbrad is offline
