MurfDogg Motor Works Discussion thread
#1022
Airland should be fun too.
#1023
Its actually alot of fun because you end up running against 25 other racers so its good practice and the class is always full with an A, B, and sometimes C mains. The format is different but I like it. I havene ran the track with the new clay but there is great traction now so its supposed to be like WC clay.
#1024
Murfdogg motors and batteries are back in stock at TQ RC RACING.
Click here to see the re-stocked items.
Thanks.
Thanks.
#1026
Check PM.
Thanks.
#1032
Has anyone tried using this motor with a Speed Passion GT 2.1 Prostock with latest timing software?
Soldered up a 17.5 in my TC, revved it up on the bench and all was fine. Ramped up with timing as expected. Placed it on the track, pulled the trigger, the car jerked a second, moved forward at 1/4 speed when using full throttle. The ESC started flashing a green light. From the troubleshooting guide it says the sensors are not being read. If you turn off\on the ESC it revves up again when holding the car as expected. Put it on the track same thing starts moving forward but with no timing and the green light is flashing again.
This motor works perfectly fine, the sensor wire is fine (works a Ballistic without a problem).
This exact same scenario happened with a 17.5 LRP X12 motor.
Any Ideas?
Thanks,
Brent
Any Ideas?
Thanks,
Brent
#1033
Any Ideas?
Thanks,
Brent
Any Ideas?
Thanks,
Brent
#1034
speed passion esc
i had the same problem with my 13.5 murfdogg motor in WGT. i worked for a week with the techs at speed passion on different programming and still had the issue. it must be a cross in the motor esc combo. you might ask Matt if he was aware of this issue with the combo. i did switch to a tekin rs pro and have had no issues.
#1035
