TLR TEN-SCTE 2.0 Kit Thread
#1846
ok, got mine all done tonight and of course i come up from RC CAVE(basement) and the ground is covered with snow again......WTF?!?!!?!?
But here is a pic all done and wired up....sold the 2 sets of rims and rings on here so i just have the cheapy duratrax banditos for running on the roads out front on there for now
And here is a link to the build pics and everything so far...
http://s1227.beta.photobucket.com/us...0Pics/SCTE%202
#1847
#1849
well this sucks.. i will not see my 2.0 for some time. LHS says probly back order until futher notice of stock. *THANKS to HCP* now all the other hobby shops that are not HCP wont see them for a while until they are in stock again....... **SUCKS**
i finally get to buy a new truck and i have to wait until how ever long to get it.
#1851
Looking to get into 4WD SCT and had a question about the SCTE 2.0.
Why is the driveline offset?
Riding the fence between the Teckin SCT410 and SCTE 2.0, and noticed this was a major difference between the two. No doubt there are other differences, but it's my first question okay.
#1852
#1853
The driveline is like that on the losi due to it being converted from the nitro 810 buggy/10t truggy. The Sct410 is ground up electric design, therefore the driveline is straight for maximum efficiency. Also a straight driveline aids in keeping dogbone/outdrive wear to a minimum. I noticed when i had a losi, the center diff outdrives wore a lot quicker up front due to offset driveshaft.
So, it doesn't really effect performance then?
#1854
I dont think having the front driveshaft like Losi has affects performance i may be wrong though. My has some wear but it will be a while before i need one on my 1.0 which the 2.0 uses the same axle and angle.
#1855
Tech Prophet
#1856
#1857
Horizon is showing stock at both warehouses!
I agree the the drive line was designed for nitro to move the motor more central but the neat thing is that works well for electric as well as it allows the battery to move more central as well! The 2.0 reduces the angle with the diff moved back so it should reduce wear some as well. With the HD oudrives wear on the outdrives is minimal. The center front drive shaft pin will still see wear but with as durable as this car is a wear item that needs to be replaced every 3-6 months is not a bad thing!
#1858
Edit: Never mind, found 'em : http://www.rc-race-and-drift-japan.c...oducts_id=3970
